Definitely an awesome and thorough job. You’ve got a clean truck and a very PMd engine bay.8 months ago I wanted you to put a clamp on it. Now I'm glad you didn't
Awesome work and documenting. I'm surprised that PS reservoir didn't make the list...![]()
Great job. Appreciate you documenting this!
You mentioned the trans seal was difficult. Any tips?
Long story short was that 5 of the 9 bolts broke. Two on top and three on bottom. Two bolts broke at the head of the bolt (leaving a long stud), two snapped flush with the head, 1 left about 1 cm of stud. Just like @excessive, I could not get any movement. Eventually drilled, chased and/retapped all 5 (over the course of 5 days about 2 hours per day). Was able to get new oem hardware on and everything torqued back to spec. New oem gaskets, tube seals, and denso plugs. Feel really lucky as this all could've gone sideways. But again "extracting" (don't be fooled by the youtube vids) these bolts, if they are stuck, are pretty much impossible to remove without breaking so really assess if you need to do this job - definitely an "if it ain't broke, don't fix" job...
This is just crazy and scary to hear. What are these bolts made out of? Butter?
My truck had the valve cover gaskets done at a Lexus dealer before my ownership ~8 years ago. And I can't imagine Lexus techs being able to be as precise with these as you mention. I wonder how this job goes down when it is done at the dealership....
Or maybe there is some age component here? When the bolts are 10 years old they are fine, but when they get to be 20 years old, watch out?
Also now wondering if this should just be preventative maintenance to change these bolts out every ~15 years.
I'm dealing with the same problem, broken stud on the passenger side. Can I ask, were there any other specific things you did to drill the studs out? I've read some folks removed motor mounts and that kind of thing. I was imagining a right angle drill with some short bits might get the job done. Any extra detail that helped you get this job done would be appreciated!I did my valve covers over Aug and Sept. Had an ever so slight passenger side oil leak.This thread was inspiring (as was the Rob Schnieder "you can do it!" Meme) as I broke 1 bolt on the passenger and which despite every stud removal technique (except welding a nut). Literally spent a week just trying to get the stud to turn. Eventually I ground it down drilled and chased/retapped the threads.
I spent the next week soaking the driver side bolts with kroil each night. Ive dealt with many, many, rusted and broken bolts with my hundy so it isnt like i just fell off the turnip truck - my eyes were wide open... My plan was to warm the engine, soak the bolts 1 last time, and carefully remove w/my quarter inch socket set. The technique would be to carefully 2 quarter turns left 1 quarter right, ect. taking as much time (and kroil) as needed to get the 9 bolts removed. Long story short was that 5 of the 9 bolts broke. Two on top and three on bottom. Two bolts broke at the head of the bolt (leaving a long stud), two snapped flush with the head, 1 left about 1 cm of stud. Just like @excessive, I could not get any movement. Eventually drilled, chased and/retapped all 5 (over the course of 5 days about 2 hours per day). Was able to get new oem hardware on and everything torqued back to spec. New oem gaskets, tube seals, and denso plugs. Feel really lucky as this all could've gone sideways. But again "extracting" (don't be fooled by the youtube vids) these bolts, if they are stuck, are pretty much impossible to remove without breaking so really assess if you need to do this job - definitely an "if it ain't broke, don't fix" job...
I was just dealing with this. Bought the induction heater just for these valve cover bolts. Got them red hot, double nut still snapped the bolt. Tried welding and every other extractor I could find. Nothing worked. These bolts are garbage. 7 of 9 broke on one side, 4 of 9 on the other.I’m wondering if using induction coil to heat the bolts prior to removal would be worth the cost of the tool? It def would melt the rubber grommet washers but those are cheap to replace
Well that sucks-I was just dealing with this. Bought the induction heater just for these valve cover bolts. Got them red hot, double nut still snapped the bolt. Tried welding and every other extractor I could find. Nothing worked. These bolts are garbage. 7 of 9 broke on one side, 4 of 9 on the other.
