- Thread starter
- #41
The alternative is not to just let your valve cover leak. The alternative is install a clamp a la post 38 which will easily stop it from leaking. The torque setting on the bolt is 53 inch pounds. You deemed the clamp to be unaesthetic but it's likely that you would be the only person to see it. You're in a fight with yourself over an aesthetic issue and probably a candidate for OCD Mechanic of the Year.more pics. I guess i am just posting this as a cautionary tale. Dont try. that's what I've learned from this. just let the oil leak from your valve covers, its a lot better than this bullsh1t
Hey at least he is living up to his user name!The alternative is not to just let your valve cover leak. The alternative is install a clamp a la post 38 which will easily stop it from leaking. The torque setting on the bolt is 53 inch pounds. You deemed the clamp to be unaesthetic but it's likely that you would be the only person to see it. You're in a fight with yourself over an aesthetic issue and probably a candidate for OCD Mechanic of the Year.
Didn't expect the issue to escalate upto this level. I'd probably apply silicone sealer on both sides of the gasket (I usually apply a small film of FIPG on the gasket meeting the head on the bottom perimeter of the gasket anyways) and call it done with the clamp shown in this thread. Throw in a rear main seal before you put it back together.
