My headlights died.. PLEEZ HELP!
SoCal - westsiiiide
so, I came back from a 4x4 trip this weekend in my Fj40. drove home at night and all was well.
Went to use the truck tonight (5 days later of the truck just sitting) and the headlights don't work now. All other lights work (turns, sides, blinkers, brakes, license plate, etc.). What do I check? I checked the fuse, but no issue there.
How do I even begin to tackle finding the issue? I am stumped at what to do?
reach around the fuse block and wiggle the wires while the switch is on. Corrosion on the terminals on the back have caused problems in the past. If the come on. Take the block out and clean and or replace bad connections. On pre 73 cruisers switches have been know to get corroded also. You can take those apart and clean them.
I wouldn't be so sure about the fuse. I would pull it, change it with another fresh one to start, then, if that didn't work, bypass with a wire. Then, if that didn't work I'd start tracing the wires back from your headlights to see if something got pulled.
Beyond that, it would help if you put your model year in your sig or somewhere.
1974.
will try what you said.
BTW, I was in the steering column fixing the horn after the trip, could I have done something there?
HOLLY S***
the fuse was bad. the thing looks perfect, no burns, still intact, not broken/fried in half, WTF? How is that even possible. had you not said it, I would have never tried it as it looks perfect and I assumed, therefore it is good.
thanks for the push!
Well I was going to say the fuse or ground but you already found it. You may not be out of the woods yest. If it does it again disconnect the battery and remove the bolts that holds the fuse holder in place and clean the contacts carefully with a wire brush and also clean the ground there too. And I bet it will go away for sure.
Do you have any other wires pigtailed around the fuse holder. That led to me burning fuses out that appeared to be good.
ha, if you only knew...... with a 1974, don't we all?
wantatlc said:
HOLLY S***
Haha! Been there, done that about 10 times. Now, you gotta think about why.
My reason was the fuse box was old and the rivet that holds down the contact was loose, causing it to ground out.
It is hell when it happens at night and you're driving down the road in the dark at 55 mph.
agreed that I need to find out why. I do have a lot of junk going on with that fuse box: old, looks dirty and grim build-up, lots of wires around it, several wires jumped into it to run major appliances (but nothing into the headlight fuse), and just general dissaray in that fuse box area. I was just stunned to have a fuse be bad that looks 100% normal. Now I know it is possible and G.I. Joe always said "knowing is half the battle."
Ya, that's weird how they do that.
The fuse is blown right at the end, where it attaches to the cap. That is exactly what happened to my stop/tail fuse last week. I spent 2 hrs searching though stuff to eventulaly pull the fuse out (that looked fine) and have the end cap fall off in my fingers. On a side note.. just fixed my wipers - bad connection in the fuse block. Doesn't even look dirty, but I guess it is!
Headlight problems in a 74 can also stem from the ground. Strangely enough, the ground on my 74 was actually the back of the switch body pressed to the back of the dash. It had built up some corrosion on the back of the dash and it wouldnt' work anymore. I thought it was odd that everytime I pushed the lights in/out they would blink. I always thought it was a bad switch, but it wasn't.
I also cleaned all of my terminal connections into the back of the fuse panel with sandpaper as extra protection.
With battery disconnected it's also a good precaution to pull the fuse block loose (2 bolts), remove all fuses (remember order/rating) and use a rat tail file to clean the fuse holders.
On my 69 fj40 it would blow the fuse sometimes, I cleaned everything up and it worked fine , I was going to just bypass the fuse and go wiht a circut breaker if it happened again, IMO a fuse for headlights is not very wise in this area when it blow there are no other lights to drive by and when it did blow it was black out not just a little scarey.
