- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,158
Which spring packs did you add leafs to?
I added them to the rear spring TOY-034-R. I wasn't sure to get heavy and remove a leaf or get medium and add one later if needed initially. I went medium way. The issue was the 4plus tire and cooler carrier is solid. @lcwizard does fantastic work. And with a load in the back of Costco/Grocery no issues - just the sag when hauling more stuff (2 people, gear, spare parts...)Which spring packs did you add leafs to?
Ah ok. Thanks for the reply. I have the same medium springs. Will have to order the add a leafs for when I add a rear bumperI added them to the rear spring TOY-034-R. I wasn't sure to get heavy and remove a leaf or get medium and add one later if needed initially. I went medium way. The issue was the 4plus tire and cooler carrier is solid. @lcwizard does fantastic work. And with a load in the back of Costco/Grocery no issues - just the sag when hauling more stuff (2 people, gear, spare parts...)
I would say depending on your usage - might not need them. But then there is the rub, right? Putting on, try, nope taking off, torque all 8 Ubolts again (and do you need new u bolts cuz the old one are stretched from all that time at 108 ft-lbs?)Ah ok. Thanks for the reply. I have the same medium springs. Will have to order the add a leafs for when I add a rear bumper
Sure did. Specs per the 1980 Toyota Land Cruiser Repair Manual, Chassis & Body is 108 ft-lb, on page 6-34You got to 108 ft lbs.?!?!
I had u-bolt stretching at 45 ft. lbs. with the Dobinson u-bolts
If a 9/16 (14mm) u-bolt is stretching or failing at 45 ft/lbs, it's a grade A or ungraded u-bolt and too soft for suspension parts.You got to 108 ft lbs.?!?!
Thanks for the info. Guess these u-bolts aren't up to the task. I need to order some of yoursIf a 9/16 (14mm) u-bolt is stretching or failing at 45 ft/lbs, it's a grade A or ungraded u-bolt and too soft for suspension parts.
Typically, among suspension type u-bolts, they are grade 5 up to 9/16 and grade8 for 5/8 and larger as 5/8 and larger are usually only
used on larger commercial vehicles. The late Cruiser u-bolts are 14mm. I use 9/16-18 for the u-bolt flip kits ( ~14.3mm) . They can easily handle
105-110 ft/lbs. 95-105 is a good range. At 100 ft/lbs you get almost 13000 lbs clamping force. The non graded bolt of the same diameter
will begin to yield at 45 ft/lbs and 5500 lbs of clamping force.
With any bolt, use the various online torque specs charts, available from fastener companies like Fastenall, Alma Bolt, etc. If the hardware you have
is not performing close to those specs, you have inferior hardware. Our u-bolts are manufactured in Illinois. I've used that same company since
the late 90's and never had a batch that wouldn't achieve expected performance
Anybody have an email for SMG so I can order the hinge pins?Wow - been over a month.
Been thinking about what I need done before SAS this year. Last year was a pant-load of work.
After cutting the military wraps, been a different ride. I got mediums springs on the rear. It was a toss-up due to the full 4-Plus tire and basket kit (that is some heavy metal) - while is just level with nothing in it - I ended up getting the "add a leaf" kit Dobinsons is now offering. I know I ranted about them, but given the new life it seems to have, spending another $60 isn't catastrophic contribution to them. It arrives Monday - that will be on my list.
Speaking of, my must do list is....
I have a long list of things I would like to do - not suitable to just list it all and will post what/if I do something on that list.
Add Leafs- Install SMG hood pins
- Address oil leak around timing cover
- Check/tune
- Spark Plugs
- Adjust Valves
- Timing
- Lean drop
- Drive/offroad it and makes sure good-to go.
@SMG's pins are legit. I have them on the door and now on my hood hinge - Still have windshield and Amb Doors in back to go at some point in the future.
Here is a video of before & after - can hear and see the rattle before and when I shake it after, no rattle or looseness.
