- Thread starter
- #141
No M8 fine thread flange bolts
These aren't flanged but they are M8 x 1.0 x 40 mm
http://www.mrmetric.com/metric-fasteners/m8-x-1-0-metrix-hex-10-9/
normally for brake lines you use a -3 an. also, most alu an fittings are not recommended for high pressure like brakes and high pressure line on power steering. you can use JIC fittings or just use pre made -3 lines for the brakes.
Does the aqualu bib come with the provisions to bolt the hood catch latch?
Can I get a pic of the inside of the bib? Later model stock bibs had a hood catch that bolts on the inside driver's side of the bib. Did you see the new Dakota gauge cluster? Racepak is going to look fantastic.
yea i did the -3AN fittings also. all the braided lines are cheap too which makes it nice.
sorry for the old MS.
Nice setup!
Can you run Braided lines the entire length? Do I even need to do hard lines?
some say they will swell to much when braking and that you should have as much hard line as possible. and i would normally agree if i was building a car or a track car but with a fj with large tires i couldn't tell the difference (well actually had all flex lines on a toyota truck) I am going to run all flex lines as it will also allow me to carry a few spares just encase. also makes changing axles or doing axle work so much easier as you wont have to take the lines off if you want to pull the third.i have been doing a lot of research on that and it seems the answer is yes and nosome say they will swell to much when braking and that you should have as much hard line as possible. and i would normally agree if i was building a car or a track car but with a fj with large tires i couldn't tell the difference (well actually had all flex lines on a toyota truck) I am going to run all flex lines as it will also allow me to carry a few spares just encase. also makes changing axles or doing axle work so much easier as you wont have to take the lines off if you want to pull the third.
