mothball a fj40
Eagle River AK
I have been doing a SOA, Disc brake, power steering conversion for close to two years now, not completely cause i am retarded but i have been deployed about 11 months out of that two years and have had anything from kids needing teeth pulled and the wifes cruiser needing a trans/tranny R2, new commuter car blah blah blah that has slowed me down. So here i am deployed again poised to have the money to become debt-free and get my cruiser done in one swift pass of the check book. good news right....yeah except the day i left for this deployment i got orders to move to england, just less than 2 months after i return home. I have 3 cruisers and i dont get to bring any of them with me, so it looks like the day i finaly finish my 40 will be the day i mothball it and put it into storage for 3 more years. So my question is what would be better.
mothball it for three years and what is the best way to do this?
leave it with a friend/family letting them start it once a month or so, maybe drive it around the block every so often (or to the trails)
the choice of what to do with it is really your own. As for mothballing it, I would drain all the fluids, pull the battery and cover it. I would try to keep it inside as well or critters will make nests in it. I have heard of others using dessacant packs to soak up moisture in the air, lay them in the back and the engine compartment.
Noah
Frame on jackstands
doors slightly ajar
ditto on the battery
ditto on the fresh oil
fogging oil in cylinders
StaBil in fuel tank
JMO
Ed
I say give it to a friend while you're away. Your friend will think you're fantastic. Be prepared for the odd scratch or more though and ring your friend often asking about how the rig is being looked after.
I normally do it to my outboard motors when retiring them for the winter. Fogging oil is available anywhere, just ask for it. Remove sparkplug(s), spray and replace plug.
GL
Ed
Where will the cruisers sit while you are away? Will they be inside or out? If outside make plans to prevent water from getting in and puddling rusting in the floors. Also taking the weight off the wheels outside on a soft surface tends to be tricky as settlement over time sets the vehicle back on the ground. If these will be inside storage consider tarps to keep bird s*** and dust off. Moth balls and other rodent deterents to keep bugs and mice out of the interior.
X2 on the oil in the cylinders. Being a military individual, talk to one of the transportation mechanics or a ground equipment mechanic or an aircraft mechanic about "pickling" your cruiser. This is what the military does to vehicles and equipment that will go into long term storage.
Pickling ussually involves putting a light oil in the fuel system and running the engine until it smokes. Drain the fuel tank, filter housing, fuel bowl and filter. Fogg all of the afore mentioned areas. An oil fogger can be purchased through Harbor Freight for cheep. Change the engine oil and filter. EVERY opening on the motor is then sealed. Carb, PVC, dipstick tube etc.. Dont be afraid to disconnect the exhaust from the manifold and seal the exhaust manifold as well. Drain the water from the radiator to prevent freeze-ups. Pure anti-freeze will freeze in low enough temps. You are trying to create a sealed package where moisture cannot enter. It's alot of work but well worth the effort in the long run
ill take it off your hands for a few years, might get some nice mods out of the deal. hehe
I have a cruiser in storage and have not had any problems. I try to start it every now and then but it does not happen enough. So every 8-12 months I will empty the gas tank if the gas was not replaced in the that time period and put the supposedly out of date gas in my truck. :) Instead of sucking the gas out with a hose I use one of those one fancy black pump things that people use on fishing boats when changing gas tanks which I bought a Accamdemy. And then I will start it for a while. My opinion is don't let a freind drive it....you are asking for it. Main thing is to lube the cylinders and for carb not to get gunk up. If noone is willing to help you just plan on having you carb rebuilt the gas tank cleaned. Also oil down your frame. You should be alright once you get the bugs out of it. I would not worry much. But if you are planning on starting it every now and then have a battery charge near by. Also try to keep in a dry place. You will be surprised what rust will do in 3 three years. And remember noone will take care of your rig as well as yourself.....:)Good luck.
