It looks like your shocks are limiting your drop.... yet when your tire is fully stuffed there is a still quite a bit more room for the shock to compress. Meaning your only using part of the shocks travel. Why not adjust them so you can use more of the shocks potential? It looks like you could easily get a few more inches of drop out of the system.
Two things I don't care for are wheel spacers and body lifts. I would do tubbing of rear fenders before doing the others. It worked great on my 49' chevy truck when I pro streeted it, don't see why it would not be a good choice here
Rear tires clear frame rails? The only other right choice would be to use wider rear axel out of?
I put a stock 60 wheel mounted with a 30x9.50 tire. This combo cleared 1". So I am going to have to buy another set of wheels with stock or about 3" BS and use 33x9.50's in order to use max articulation and clear the shock bodies. This should help at the rear also. I thought about notching the Ford towers and bend more straight but that will cause interference with the shock body as it fits into the tower eye at the top and with the steering box u-joint.
Been out of town and unable to work on the 60
Was not bad at all. Followed Mace's porting thread
