(Firstly, yep, I’ve searched and had a good time reading the various GPM/PSI/power steering/hydroboost/electric winches suck
/hydraulic winches suck
/stop-complaining-about-the OEM-power-steering-and-just-install-your-winch
threads.)
I'd like to raise the stock power steering pressure of 1200 psi to a value of 1500 psi in order to fully power a hydraulic winch per the manufacturer's recommendations.
Mile Marker states the minimum power steering requirements as 3.5 GPM @ 1500 psi (13.25 L/m @ 103.4 bars) that their "HI" series of hydraulic winches. Without this minimum supply, they estimate that there will be a 30% power loss using the stock 1200 psi system. By the way, through all my searching, I haven't come across a factual GPM for the OEM pump.
This equates to a $1300.00 USD 12,000 lb hydraulic Mile Marker winch being handicapped and rendered an 8400 lb winch. This is a hefty price to pay for a winch with borderline capacity for an 80 series.
So, I've basically got three options:
(A) Quit my searching and put the biggest hydraulic winch on that I can afford and use the stock power steering pump (Landtank has had good and lasting success with this option).
(B) Mount an auxiliary pump like a PSC SP1200X (which is rated at 1600 psi and 4.5 gpm) like Christo did in the Shortbus; an auxiliary pump that has a selectable clutch would be best.
(C) Modify the stock pump to boost the pressure to around 1500 psi. My truck is my daily driver, and I will say that I'm a little concerned and apprehensive about modifying such a critical system that my passengers and I rely upon.
The first two options are fairly straight forward and commonsensical. So, my single question, concerning the third option, would be....
Has anyone successfully raised their power steering pressure without busting hoses and burning up steering pumps? I've read a bunch of people mentioning that this could probably be done, but I haven't come across anything concrete except this archived thread on Pirate.
threads.)I'd like to raise the stock power steering pressure of 1200 psi to a value of 1500 psi in order to fully power a hydraulic winch per the manufacturer's recommendations.
