I work in the papermaking enineering side of things for 34 years now and to be honest I think there is a lot of bull s..t when it come to lubrication and applications.
I am not knocking the engineering of our Landcruisers when it comes to engineering, but to be honest, it is the basic you will ever find when it comes to precision engineering, we spend far to much on the highest quality lubrication, but to be honest, using mediocre lubrication will be just as good as using the oils that cost 4 x the amount.
All automotive lubrication comes from reclaimed industrial oils, ie all the waste oil big companies use then throw away, it will be full of crap and water, but will be refined to use on cars and trucks.
So using a really expensive diff oil on a FZJ80 diff will make no difference to using a standard half brand name EP 90
But if you feel better using oil that cost 4 x more than a good quality oil then its best you do, oil companies know this and rubbing there hands all the way to the bank.
The only time you need to change oil more frequently than sugested, is when its been contaminated or has been overheated, which will lower its lubrication properties, filtering is the must, if diffs had filtration, you would never ever have to change the oil because it is really unstressed even in the most demanding hill climbs that our cars could do.
