Mobil 1 moly - does it exist?
Corsicana, TX
I am getting ready to do a front axle service, and I am collecting lubricants.
  1. Mobil 1 75W90 for the diff
  2. Mobil 1 synthetic grease for bearings & brake pad lube
  3. Birf grease: calls for moly, is there a Mobil 1 product for this?
If not, I will find some of the synthetic Valvoline moly grease others are using, but until I know its the only option, I want my bottles to look the same.
UP UP UP
Did you search?
I searched and read quite a bit.
My guess is no such Mobil 1 product exists, not having read about it in the many grease and axle service threads.
This thread is a last ditch effort to verify that.
Correct me if I am wrong, but I recall reading on this forum, by some well-regarded individuals (I think IdahoDoug?), that using synthetics for birfs might not be the best bet (at least filling from the knuckle). Synthetic greases are quite a bit thicker than their regular counterparts, and can have a harder time penetrating to the birfs.
This is frustrating.
Mobile 1 has no moly, so I looked for Valvoline Palladium.
No one around here has ever heard of it, including NAPA.
We have Napa, Autozone, O'Reilly, and a mom & pop.
No one has it.
The FSM is unclear on this. What % moly is required?
In an old post, Cdan recommends Valvoline 985, but they apparently no longer use that part number.
What is 985?
I've found labled "CV Joint" grease is 3% moly and most that say "Moly Grease" is either a 3 or 5% mix. I've also noticed the 3-5% moly grease is smooth and creamy, not thick and tacky like wheel bearing grease. I would agree that moly grease can flow into the birf probably better than wheel bearing grease.
NAPA carries the full line of Valvoline grease. Have them pull out the commercial catalogue and order some tubes of Palladium. At every Napa I've been in, there is Palladium on the shelves.
palladium is the cheapest and best bet. Any Napa store can order it.
I usually shy away from ordering, but I called anyway, and Napa said it (Valvoline Palladium) will be here in the morning.
I ordered a case of tubes. Don't take "we don't carry that" for an answer!
Thanks for the help everyone!
I work in the papermaking enineering side of things for 34 years now and to be honest I think there is a lot of bull s..t when it come to lubrication and applications.
I am not knocking the engineering of our Landcruisers when it comes to engineering, but to be honest, it is the basic you will ever find when it comes to precision engineering, we spend far to much on the highest quality lubrication, but to be honest, using mediocre lubrication will be just as good as using the oils that cost 4 x the amount.
All automotive lubrication comes from reclaimed industrial oils, ie all the waste oil big companies use then throw away, it will be full of crap and water, but will be refined to use on cars and trucks.
So using a really expensive diff oil on a FZJ80 diff will make no difference to using a standard half brand name EP 90
But if you feel better using oil that cost 4 x more than a good quality oil then its best you do, oil companies know this and rubbing there hands all the way to the bank.
The only time you need to change oil more frequently than sugested, is when its been contaminated or has been overheated, which will lower its lubrication properties, filtering is the must, if diffs had filtration, you would never ever have to change the oil because it is really unstressed even in the most demanding hill climbs that our cars could do.
XHP 462 with3% Moly
Well it's not mobil 1 but it is still mobil grease.
Snowwolf:
My guess is you are right, but synthetics (at least in the US) are not 4X the price anymore.
I don't have my reciepts at the moment, but I think my diff oil and bearing grease ran about 1.5x conventional lubricant. I know synthetics are technically better, but I have no idea how those numbers work out in the real world. Maybe my bearings will last 0.00001% longer?
Squash and Rock_wagon:
I've never heard of those before. Someone should add them to the lube list if they're not already there.
It seems from all the reading I've done on this that birf grease is the lube most are unsure of.
I've still not found in my FSM what concentration of moly is called for.
Since I am now the proud owner of a case of palladium tubes, mine will be 3%
I live in Dominican Rep, and most of lub change store carry only cheapest grease / oil around, say, big drum of Shell or Texaco grease, and there is plenty of 70, 80, 90, 100 series cruisers around, all use same drum of grease, and I rarely hear from axle problem, and those trucks is abused on bad roads, high temp everyday. What I observe is that people tent to change their fluids very often, maybe every 3 motor oil per one differencial oil change, and grease to joints every oil change etc, so I conclude that frequenty oil change is a good practice, ragardless of what type of oil, in extreme condition of driving..
I am about to do the front axle job soon, so my plan is use highest quality of grease on bearings, and make sure that they seal well, and use the cheap differencial oil as everybody else use here.. hope this works :hhmm:
Mobil XHP 462 with3% Moly
I gave up trying to buy Paladium and found CAT grease with 5% moly.
