Minimum Height with SOA
Whitinsville, MA
I have done a lot of reading in the FAQ but can't seem to find what the minimum lift you could get out of a SOA. I want to try to stay as close to 4" as possible and run 35" tires due to local lift laws (I don't mind a little fender trimming). If I go this route I will be switching to FJ62 axles as I already have them. I have a buddy that has done a number of Jeep SOA swaps. He thinks that I could get less lift using wrangler springs due to them having less arch. Also does if anyone has suggestions on spring hanger locations that will help I'm all ears. I am still undecided if I will go the SOA route and I'm not asking if I should as I have read the pro's and cons to both.
Below is the current pic of his Jeep we are workin on.
measure your axle tube then another inch for the perch and there you go. so around 5, 5 1/2
Is there any way to play around with the different springs or raise the hangers to get less lift? I would like to try to avoid a harsh ride and limited articulation of 4" springs however it looks like this may be my only option.
what kind of springs do you have, i would run stock springs, ride soft and flex well and you should be fine if you are only running 33-35 inchers, if you want the front to be lower run the bushings through the frame instead of under in the front, i cant really tell what you got going on in the rear hope this helps
never mind on the hangers above, not your rig in the above photo.
You can use some short front hangers and go through the frame in the front.
And re-locate the rear hanger. The rear fixed spring mount point is harder to re-locate.
I have a soa 40 that is lower than my brothers (his has a 4" lift) my springs are very broken in. It rides better than any 40 i have been in. I run 16/35 boggers and can flex them more than i have ever needed. So just depending on your spring rate and how fatigued they are you can achieve anywhere from 3.5" to 6" lift. Hope that helps
Thanks for the info guys. I was planning on using a short front hanger.
I will have to look more into what Mace did.
yeah, frenching the frame like that would get you a couple inches lower, but remember that to get full articulation of the axle, your springs should be able to reverse arch pretty good when flexed...well, on stock springs anyways.
i think that frame mod would be way easier to pull off on the rear of the frame b/c in the front you would start gettin into interference between the axle and the engine...
to lower the lift, #1 thing for me would be to nix the 4in lift springs and go for stockers.
malphrus
Forget the suggestion of Wrangler springs. If you OEM springs are not flat already, they will be after a short time in SOA configuration.
Mark...
Bah. Poor argument, since spring under trucks have no interferance between engine and axle.
Steering on the otherhand....
try using stock springs SOA and adding some long add a leafs from man a fre. I did this and it worked out well. I agree that the stock springs SOA will soon become so flat they will be inverted, mine did. That's when i added the long leafs and it helped greatly. It rides great now, and the solution was cheap, free springs and $40 adders. pics shows with 33 muds, I now run 35's no problem.
Noah
good point. actually very good point, ha ha.
malphrus
I first tried blazer springs about 6 years ago in SOA configuration...trying to stay low. They flexed ok but the stock springs would have been better.
I swapped in waggie springs and they are much better. I can jump it in the dunes (small ones) without the massive jarring of bottoming out like the negative arch blazer springs would do. For some reason they also flex WAY better than the blazer springs.
If you can, stick with stock cruiser springs. I tried to keep mine low but it didn't quite work out so I went wide.
Taking a spring out is not the route you want to go. More than likely you will need to add a spring like others have already said.
My soa crawler has leaves added to negate too much negative arch, which will eventually end in spring cracks.
My soa daily driver has no springs added and will not likely need any since it does not ever flex except over the occcational curb.:)
check out 4wheelingplus.com. he has pics of a minimized fj40 front end. thats the model i'm following. frame modification in front and spring location/ hanger modification in rear.
:beer:
