- Joined
- Jan 6, 2012
- Threads
- 340
- Messages
- 10,956
If your driving that far, I would install cruise control. Seriously. For about 200 bucks and a bit of labor it will make the drive much easier.
That Yellowstone loop is beautiful drive, but a major time suck. Instead of coming back down to Jackson, you could go out West Yellowstone. Traffic is better and gets to different scenery. Hwy 20 would take you to Idaho Falls.
Yea it's just a matter of the amount of time I have allotted for this trip. I have about. A half day to get things ready when I return to NY this weekend before I've got to go.If your driving that far, I would install cruise control. Seriously. For about 200 bucks and a bit of labor it will make the drive much easier.
You would recommend something like this:That Yellowstone loop is beautiful drive, but a major time suck. Instead of coming back down to Jackson, you could go out West Yellowstone. Traffic is better and gets to different scenery. Hwy 20 would take you to Idaho Falls.
If you saved time on that loop, you’d be hard pressed to not enjoy a drive through Stanley Idaho. Dropping down from Challis down through Stanley to Ketchum.
You would recommend something like this:View attachment 1757753
I'm planning 2 nights in the Yellowstone NP area. You don't think that's enough time to drive the major attractions through the park?
Like most things it depends:
Are you getting out of the car and hiking around?
Are you planning to see the sights from behind the wheel?
When are you planning to go?
Are you staying in Jackson?
It’s the height of the season right now, so expect the roads to be slow driving. Every time someone sees an animal the traffic comes to a halt or slows down. There’s a lot of animals.
*** I’m not trying to dissuade anyone from visiting Yellowstone. I think everyone should see it, just be prepared. *****
I took the family last spring(low season)up through West Yellowstone to old faithful and down to Jackson. We spent the night in the park at a campground. We saw a couple mud pots and old faithful. It was a a solid two days.
If I was going to do your route I’d start in Dubois or Jackson EARLY. Make your way through the park with a plan to stay in West Yellowstone. Then head over to Challis and Stanley. This is personal choice, but the sawtooth are more spectacular to see.
Cruise is built into the ECU. Just need a switch for set and a brake switch to turn off.If your driving that far, I would install cruise control. Seriously. For about 200 bucks and a bit of labor it will make the drive much easier.
Does this count as seeing the Sawtooth range:x2
I'd go through the winds in wyoming and the sawtooths in idaho before the tetons and yellowstone. Like Archie says though, it's a personal choice - and everyone should see those nat'l parks at least once
Awesome!Beautiful job on the install. Not trying to high jack your thread, but here is a couple pics of mine. Almost on the road. I see we have the same tastes in intercoolers. lol. I didn't get to read your whole thread yet, as I wanted to show that I knew what you went thru with the wiring and install...
Cool build. Be aware that when that engine is operated at high duty cycle, the EGT and oil pan temperatures can quickly go too high, especially on a modified engine. Do not pull the oil temp reading from the oh-so-convenient fitting on the filter head, as that is the oil temp after the cooler. Get the pan reading. Since the turbo cooling oil and piston cooling oil are both dumped back into the pan, the oil temp in the pan is the highest in the oil system. On a steep grade at highway speed my modified TDI can push the EGT past 1200F (I let off at that point) and after a minute or two on a long grade, oil pan temp climbs past 270F (I let off at that point).
Awesome!
Looks like a clean install!
You gave the Treadstone TR1035? It seems to work well in my application, with inlet temperatures 10-15*F withing ambient.
Yes, Treadstone makes some very high quality coolers that seem to fit nicely in the 40.
Which transmission are you running?
I am running an NV3550 out of a 2004 Wrangler.
Make sure you plug the check valve port on that radiator if you are going to retain the VW coolant ball.
Which turbocharger did you choose?
Yes sir. Thanks, not quite done under the hood yet.
I used a VE engine for my last project truck, it was awesome! I ended up doing quite a bit of work to that engine, but kept the small OE turbocharger for its awesome transient response. I opted for the PD this time for the extra output and the changes made to the bottom end primarily.
The turbo is
03G145702H turbo from Darkside Development
also running a PD150 intake. I like your air cleaner assy, I need to rework mine yet. I put the cone on there to get it running fast.
Mike
ichAre you using the Gastodiesel motor to trans adapter? I went with the Coty Built adapter and after the fact wished I would have used the Gastodiesel.
I do have a second motor I was gonna play with the internals after this is on the road, just for fun and push the power a bit more. My friend who does the computer tuning for me basically gave me the same numbers for the tune he put in it now. 180hp 320ftlbs torque. thats almost twice what the cast iron F had that I took out.
If you have problems going by Minnesota hit me up, I am a few hours north of where you will be crossing the state, but if you are in trouble I will come help!!
