METHOD WHEEL QUESTION
I'm waiting for a buddy to buy my 275/70 Ridge Grapplers and I'll be following suit with a 295/70 Ridge Grappler. I believe it's about a 1/4-1/8" shorter than the STT Pro. But I'll report back in when it goes down. Just waiting for buddy to commit!
How big of a spacer are you running? I’m happy with the poke and figment of +18.
Lighting makes that photo look dope, nice truck and enjoy it!! I love Method wheels and they offer a hand full of looks for our trucks.
No spacers. That would be pretty extreme with this offset haha (as you know).
Method Roost 18 x 9 x 18mm offset with 295/70-18 ST Maxx (34.49) 2.5" TourFlex coils and front is at 22.00"
Front center cap will be bored to fit over/through the front cup.
Ok so is +18 offset the way to go vs the +25?? I just want to run 285/65/18s. Methods seem like the way to go but im not sure what offset I should get. All these setups look great!!!
depends if you want lip or concave. NV or roost is more concave style all others are lips.
Either will work on our trucks, just depends on how much poke you want. I have no insight into any issues that could arise from a stock suspension and these wheels and your tire size though.
Considering going with 17x8.5 Methods +35mm and 295x70x17 KM3s. What do y’all think of that combination? Will it work?
^^^ That combination will work fine.
So is 70 the tallest we can run without getting into any rubbing issues? I don’t think I want to run as wide of a tire as huboverland. I’m thinking 275/70/18 on +25. I want them to be one size up from stock tires and a hair past stock on the poke
Thanks for helping me out!
Try playing with this calculator to compare two tire/wheel combinations:
Wheel Offset Calculator
thanks so much. Im in such a time crunch to get this truck built and road ready, common sense isn't working... ive settled on 285/60/18 on a 18x9 with +18 or +25 offset. thanks so much for your help
Now I just need to figure out if I want the Toyo ATii or the ridge grapplers....
you can go larger than that size tire 285/60/18 = 31.5 diameter.
I'm on 275/70/18 KO2 = 33.2" diameter on +18 methods. these 33's also fit in the spare area w/o mod. Also 50k mile warranty E rated tires
I have slight rubbing with these Method 701. But I am running a 12" wide tire that measure to about 32.9. Lift is going on today. I just dropped it off at RPM Garage in Monrovia this morning. Super psyched to see the finished result.
