You can’t move the AC dryer up inbetween the battery and radiator where it was mounted in pre 94 models. I did it on the 96 I’m building. This mod is documented here on Mud.
The slots should land on the formed bump outs on that lower sheetmetal crossmember. If they don't Im wondering if that bracket got bent 180 off. Also when you have the intercooler mounted the stamped logo on the top of the logo should sit off to the passenger side of the latch mechanism.Worked on the intercooler for a little bit. Got it mounted up for the most part. The bottom bracket is not centering up for me and those holes need to get drilled and rivnuted in the crossmember. Seems like the bracket holes are offset to the passenger side causing it to push towards the driver side. The long side of the bracket is on the driver side if that makes sense @Cruisers and Co how’s this looking?
The picture above is from the intercooler thread. The holes seem offset towards the driver side, long side on the passenger side.
We will check all the brackets at the shop for this and get you a correct oneGot the @Cruisers and Co intercooler mounted. Had to make new holes in the lower bracket, got the rivnuts in the crossmember and used an air saw to cut the big holes. Need to work out the ac dryer, trim up the grill, lower valance and start putting the front end back together. Really hope the winch clears the intercooler. Now I need the turbo parts back from coating! Getting close.
Ah… we’ve not tried that one. The regular version does fit if you do swap out bumpers. So does ARB, BIO, Slee (with minor mods), and Belfab. I will rack my brain and try to come up with something. It does not look like it would be that hard to push the bumper out and weld on some 1/4” plates to relocate those holesDissent extreme clearance
Also saw Ben last night back at the C&C headquarters
View attachment 4187323View attachment 4187324
