If only full aluminum rads were more common and not so many dollars. I believe in engineered plastics, but would be all over that!
Your viscous fan should engage at higher speeds. I know this goes against conventional understanding and thinking but I have proved it
How did you prove it and where can I read about it?
Allow me to gently suggest...any replacement radiator will likely be another copper/brass one because I just don't trust plastic;
- so many time over - here on this forum. Search (for my name, for one) and read from now until next week...Allow me to gently suggest...
Your apprehensions about plastic radiator tanks, having shared that feeling, and, as a result, having suffered through two years of un-nessesary frustration, limping by with an (almost) non-functional cooling system - here in the hellishly hot desert southwest US... are completely unfounded.
Look around you - every modern car, from every manufacturer... Plastic tank / aluminum core radiators - running literally all over the world - for how many decades now?
Let's be practical - if you get one of the statistically unusual leakers - well then - shrug - order up a new one. They just aren't very expensive, and the replacement procedure isn't difficult or high skill.
p.s. This subject has been absolutely -- so many time over - here on this forum. Search (for my name, for one) and read from now until next week...
Good job your not posting that on a Chevy forum in the V8 section.This isn't this hard as this forum makes it out to be. Optimum cooling is:
* remove thermostat entirely. No thermostat means MAXIMUM FLOW and no parts to break.
