- Joined
- Apr 28, 2008
- Threads
- 61
- Messages
- 917
so other than my newly milled head and gasket; what other issues can overheating cause in components. HG and radiator gonna be redone at no charge by Mr. T but it 1) it was so fast to spill it went red in a split second and was in the red for 25 minutes roadside. 1) I've got to fly to Texas, rent a car and then come back up here to Colorado at some point and pick it up. "Gina" at the dealership basically blamed the radiator on it as it wasn't mounted correctly before they did the work? WTF? Nearly 7500 bux to have it done correctly and 12 miles outside the dealer my baby beaches herself on I-25. They also broke my EGR SENSOR which they compensated for by adjusting 2 shocks....anything else they need to replace after a 25 minute heat soak? I'm so pissed I can barely type,
The topper is Gina stated " you took it to full operational temperature". Yeah, no s*** it's called driving! I asked her if they did that and she said well we didn't drive it ten whole miles. Great work. I'm gonna be disputing some of this with my CC company. Anyone have experience with that?
Rant ended for now....not once has she left me stranded. Except this this work by Larry Miller of Colorado Springs. Fawk this!!
Here is the list of my last few weeks I've done or had done. And they miss the most basic check-up to heat and drive more than around the dang block!
See attached photo of the Toyoya Red Coolant stain-massive.
Maintenance
Head Gasket
Front main seal
Rear main seal
Distributor O-Ring
Valve Cover Gasket
Front axle service-trunnion bearings-axle seals
Thermostat
Water pump
Seats fore/aft-not done
Blue fan clutch upgrade
Fuel filter
Brake pedal feel-likely master cylinder
Driver side visor-290?
Alignment
Steering wheel center
Spark Plugs
Front differential fluid change
Drive pulleys
idler pulley
Heater hoses
Shocks-FR and LR
Maintenance
Head Gasket
Front main seal
Rear main seal
Distributor O-Ring
Valve Cover Gasket
Thermostat
Water pump
Fuel filter
Alignment
Spark Plugs
Drive pulleys
idler pulley
Heater hoses
Shocks-FR and LR
