Build Lynchburg Lemonade, matzell's STW
I started on my tailgate today...
Tailgate is almost done. I am still deciding on hinges. I may use the barn door ones like others have done. I had to add another piece to the rear sill to get the door to sit flush.
I also corrected the spare tire carrier. I always liked it but it was weak on the thin sheet metal quarter and a 31" tire would hit the body when open. I extended it 6" with a sleeve of 1" dom and a top of 1.25" dom. It should now open all the way without hitting the corner and allow me to drop the tailgte. It should be good up to a 36" tire without hanging out past the side of the body. I always hated it sticking out and rubbing on trees and stuff when you get too close. I have missed the tailgate of my old 85 4runner when we stop for lunch. Great place to make a sammy!
For that long patch piece across the bottom, did you use a break? I need to make that same piece for my tailgate but don't have a break.
I clamped the middle piece on my work table and used a hammer to bend it. The side pieces I used my Swag press brake for the middle bend and then clamped it on the table to bend the short bend. I used a piece of 3/8 stock to hold the sheet metal in place as it was clamped down and then slowly used a hammer to bend the edge. works pretty good for thin sheet metal.
Since the Ruffstuff latches would not work, I went to plan "b". I used to right side latches to make a left and right. Then made up some catch pieces. Turned out well and gate does not rattle. 31 bolts holding it all together!
I found some cables that come with shoulder bolts that work well. Dorman and others have same part number.
