LX470 Stereo Upgrade with Nakamichi
I just went through this installing a Joying Android head unit. Splicing the factory wiring was not difficult using the legend on TLC faq and in this thread. For the speaker wires, I used the screw-post type RCA connectors into the head unit pre-amp output jacks:
50Pcs-Phono-RCA-male-plug-TO-AV-Screw-Terminal-Block-Plug-Connector-CCTV-CAT5-To-Camera.jpg
They don't provide the most secure connection and are really jammed in back there so I might have to switch to a proper low-profile, right-angle pigtail the next time I'm in there (still have to plug in the GPS antenna, back-up cam etc.). Pretty happy with the results, though:
[/URL][/IMG]
[/URL][/IMG]
Hello, did you e
Hello, did you install the GERI waterproof CCD Car rear view backup high-definition night-vision general reversing camera? IF so, was the stock wires long enough, Thanks
No I haven't installed the camera's. I lost enthusiasm for taking the dash apart again and again, just enjoying the radio for now. Will go at it again soon and finish up the camera.
Thanks for your help. I just finished my install.
I ran the ebay double din knock off version from the ebay seller "spiral installations" it was 40$. The fitment was ok and sounds a lot like you described with the beatsonic needing a touch of superglue. After that was done it looked very clean. Well worth its cost.
I had to run RCA to speaker wire kick downs with my install. I installed an avic 4000nex carplay and when SIRI came on she sounded terrible and was overpowering even on low volume. This when I was running through speaker the wire hookups on the back of tIhe radio. I could hear a little feedback as well. Its funny because the radio sounded great, but in carplay SIRI and using apple maps it was terrible.
I was able to retain my factory subwoofer using the RCAS because the 4v preamp was closer to the actual output of the original NAKAMICHI.
For me running through pioneers original internal amp disabled the subwoofer.
I would recommend using the RCA to speaker wire method if you have front and rear speaker outputs. looks something like this.
Hello, I have a 2000LX470, with the
Hello, I have a 2000 LX470 with the Nakamichi. I follow sk8salomon direction to a Tee. everything went find. I installed a Pioneer 8000NEX However, when I turn on the radio the volume is at a plus 5 and very loud. I have to turn it down every time the radio is powered on. I am also hearing static from the radio when the ignition is at ACC. Can you confirm if I use two of the High level speaker to low level RCA adapter I would retain the factory subwoofer an the static would disappear? Thanks for everything
So I have read this thread and I have a question, the speaker is a two way speaker, where does the crossover happen? In the door, in the amp? Do you need a ??? Channel amp. Thank you for more knowledge...
Beware of getting this unit from Sonic, Pioneer clearly stated that Sonic is not one of the authorized retailer and will not qualify for Pioneer $150 rebate. I almost pull the trigger then back off after looking at the rebate condition. :bang:
Right you are...Thanks for the heads up ranma21!
Ouch! I sure hope Crutchfield is!
Sonic couldn't take a call, and then did not email me back, so they did not earn my business...
Yup Crutchfield is valid with the rebate =)
