- Thread starter
- #61
yes, had to weld tabs on the tie rod and axle. the redneck ram kit came with everything needed.
the only time i notice it is if im driving kinda fast in the woods and try to jerk the wheel to miss something. it basically wont let you.
not much learning curve. when im driving on the road at speed (the small amount that i have done), i dont really even notice the hydro-assist. once you're rolling pretty good, it drives just like normal. you could jerk the wheel or swerve around something just fine. the only time i notice it not being able to keep up is when the engine isnt turning enough rpm (like if i take off through a small straight stretch in the woods and then let off the throttle to slow down for a turn, it can be hard to steer). otherwise, the pump keeps up just fine. i wouldnt have any problem running this setup on a daily driver.
i dont think any of the other toyota pumps will work without lots of modification because the FZJ80 has a gear driven pump.
LT said:If someone had an 80 series pump and one from a 3.4L or 4.0L Toyota v6 to verify then upgrading the pump is a viable option.
