I personally wouldn't worry about it. Machining and tolerances are much better now than they used to be that a break in period is kind of moot. I know many engine builders that will take a brand new built engine and put it straight on the engine dyno for full WOT passes.
Just sell me the supercharger. You'll be happy you did.
Meaning Ill like it without adding SC or?I think you'll like it. It won't be crazy power, but adequate. Since I missed out on the SC for the LC, I'm probably going the LS route. Not cheap.
With. I have one on my Tacoma and love it. However, I've made other mods in the search for even more power. It's kinda quick now. I like speed. LC isn't about speed.Meaning Ill like it without adding SC or?
I am completely rebuilding my 97 engine including +1mm pistons
I have a brand new SC kit Im considering installing
Any recommendations about breaking engine in before SC or not?
What are the odds of being satisfied with port/polish, balanced, +1mm, cometic hg, being enough performance upgrade on my 300k LX?
Wow, sweet
Transmission etc holding up?
Oh and I had a small overheating issue but it was barely discussed.
That is what I did for my new engine with SC. I goes like a stabbed 2.5 ton ratAt least give it the gold standard break in. 500 miles on cheap mineral oil, flog the crap out of it at the 500 mark. Take it for a few passes down a hwy on ramp to get the rpm's up. After that, go home, change to whatever oil suits you and drive it.
Ill keep that in mind as I believe I purchased one of the last kits manufactured.
33", 2 1/2", Icon 2, 410, ARB lockers
Expedition, no towing....California based
Being in CA is a game changer when it comes to the idea of a motor swap vs a supercharger.
I have a TRD one I suppose I'd sell, but realistically the market is CA guys as most (well, many anyhow) other states allow for a swap motor if you wanted to go that route. Varying degrees of "hoops to jump through" really.
I wouldn't be concerned with installing within the first few hundred miles (drive the motor long enough to verify it's 100% as a NA motor, then add) -- but if you have any plans to run a smaller pulley or customize the S/C kit then any hop-ups would be something I'd get the motor through the initial break-in before going for more from the S/C above the stock output.
