Ls1 fj62 build
Clover sc
Started with a one owner pretty clean cruiser has one rust spot on drivers rear quarter panel. And drivers seat has a small tear in not bad for a 300k truck. Started by pulling body off so we could get motor trans and transfer out and back in easier.
Cut off out put shaft on new transmission for adapter. Measured 4 or 5 times and went over directions several before I did it though lol. Got all bolted up. Hopefully next week will mock up in frame. This all have done now. Only have Monday afternoons to work on it and have been working on it for about 2 months now so not to bad.
Any updates?
That frame is beautiful...
This may be a dumb questions, but how did you know where to weld up the new motor mounts with the body off the frame?
Bolted up the motor trans transfer case and drive shaftes. Then welded in place had to modify trans crossmember to move transfer case forward 2” so didn’t have to cut drive shafts. And I did some measurements before pulled body to see where stock motor set. And new it was good but longer than ls1 motor.
