Lost Ignition Key?
Near Junk
Not sure if this is Tech or not but............
I can't seem to find my keys for my '76 FJ40. Can a locksmith re-key the ignition? I assume this can be done - just checking here as I have no experience in this area.
AndrewT
He can rekey it, or make one that fits. You might prefer this for the keyed gas tank cover
My key will start almost any 'cruiser. Need a copy?
tru sometimes ive used a thin screwdriver when i lost my key
If you only need a key for the ignition, as in you have no gas door, and run a soft top, it's probably cheaper to just buy a new ignition cylinder. With new toyota keys to boot. Shouldn't be too tough to change. I changed the ignition switch, not the lock cylinder in mine in about 5 minutes. If not, yes a locksmith can re-key it.
TexomaFJ40 said:
Anyone have a pic/location of eman's cruiser? :)
How about his address too! The scary thing is, any fj40 that isn't locked could be stolen very quickly with a phillips screwdriver and a regular screwdriver. There is no ignition lock, and the ignition switch is only held in place with one screw. Once the screw is removed, put anything (like a regular flat screwdriver)in the switch , turn it,and the truck will fire up. Yet another reason I rarely let mine out of my sight, and keep it locked in a garage whenever i'm not driving it. Living in the sticks helps the security issue too.
My 81, 79, and 78 Chevy LUV trucks were all the same way. One key fits all older vehicles.
My cruiser is securely locked in the garage with the front axle dismantled right now so it ain't going anywhere. :D
I am gonna rig up some sort of key fob thing in a discreet area that will kill the ignition if I have to leave it unattended for any length of time. Once I have some money in it I am seriously considering a Lo-Jac system.
