Looking for 2 cabs
finished welding the body mounts then made the cuts
then test fit the bed and found where i'll need to cut it, the front half of the fender will get cut off and grafted onto the cab
got both rear fenders fully welded
and inner fenders done too
started to plate the interior
This is turning out to be one of the most taleneed pieces of body/metal work I've ever seen. I'll stay tuned!
Thanks
Here's an update:
finished plating the inside and got the support between the b-pillars in
getting things smoothed and sealed/primed
this came in
need to build a stand for it, and going to get an air over hydro ram
here's a quick line drawing of what i'm kind of thinking for the cage, not really sure what i'm doing as far as the bed is concerned though
finished the door hinge for drivers side
and the upper exterior of the b-pillars
I set out some pieces to figure out the roof and will start welding it up tomorrow then on to body work and finishing
you know what would be cool on that thing? a retractable canvas top like the old vw's had.
here's the work from about a month ago:
framed up and tacked in the sun roof section
then started to fill in around the edges
ghetto sheet metal working skills
more template making
finished product
fit of the glass
[/QUOTE]
and that brings it up to date to today:
rolled it out today to do the body work on mike's half doors, finally decided i couldn't wait anymore for space in the shop to open up so put the wheels back on and let it get some sun
and threw the bed on just to get an idea of what's left to be done. Still need to trim the fenders, slope the bottom edge behind the wheel, and maybe a dove (still debating that one)
Looking good! Put some tan on it!
picked up a ford tank, out of a '93 f-150. Extended the frame back out just a little bit and cross member replaced
going to get the tank mounted solid tomorrow and lines ran, then it's on to mounting the bed and body work
got the tank strapped in and lines ran, will build a skid/cage for it later on
got a little bit done, finished cleaning the sender up and re-worked the float so it wouldn't read backwards
some work on the rear doors, they're just pieced together in these pictures trying to figure them out
and i'm thinking of turning the besides into tool boxes like you see on some new full size trucks like this one:
here's a little update, got the fuel filler neck tube ran and kept it on the passenger side, personal preference
then started working on the bed wall
just for reference i set the shocks about where they will be mounted to the cage that will be between the cab and bed, fuel filler will also be mounted to the cage
then started skinning, the two sections to either side of the center will have removable panels so i can easily get to the shocks or anything else back there
