I have an old 50? gallon tank from "Pighead" that I want to install in my truck. I had indicated earlier that I might make a run of long range tanks but now that I have one myself there is not a real urge on my part to do that.
IF folks want a long range tank I can ask about the cost to copy this one before it goes under the truck (probably a month or two out as a diesel piggy is quite good on fuel especially since it's not driven every day). IF there are enough who are interested BEFORE it goes under my truck I'll get some prices. At that point I would need prepayment from anyone who wanted a tank BEFORE making the fabrication run. There will be one run ONLY (and only if there is sufficient interest) so if you snooze, you loose!! Let all piggy owners know if you want this to happen. A single person to receive the tanks stateside (and then ship out from there) would probably make shipping cheaper too.
Post up if you're interested. Also post up if there are any changes or special needs that folks might want. Pighead had suggested that perhaps an integral skid plate (extra thick bottom) might be an idea. A mod I'd like to see is mounting to the OEM bolt locations or the frame to carry the weight as I don't like suspending that weight off the sheet metal cargo floor.
We won't be making custom tanks so if you need an "in tank" pump or other special item you'd be doing your own modifications once you get the tank. This should not be a problem since they will be unused at that point so a shop stateside shouldn't have a problem doing work on it.
DD....lots of people have looked in to this in the past.......sent some cash in a few years ago to help Jim C who was doing some research on long range tanks but haven't heard anything on that for several years now; it isn't the fact that it is long range I consider it bringing the vehicle up to what I consider a normal range between fuel stops.......say like about 350 miles; with the fuel burn on the 2F and F motors have to refuel about every 250 miles which is a royal PITA.........yes, I realize the added weight will cut down on MPG but I believe the trade off is worth it..just my 0.02
, LOL, I don't think we'll have a problem.
