Locker Question ?
Central Cali
Looking to get lockers for my 77 fj40, between the ARB and the aussie lockers.. what are your opinion's of the two ?? or is there better ? i only like to buy quility sh$$. also who has the best prices for either ?
any info is appreciated ...
And , :cheers:
if your rich buy the arb, if you rich but would rather save a dime or 2 get the aussie. depends on what you plan on doing where you drive what axle you are going to put it in?
i vote rear aussie front arb,
if its a dd arb in both or if your loaded
try a search, tons of opinions
and look in the marketplace, or offroadlockers.com
;) ARB is the SONY of lockers. I'm not sure, but i believe that an aussie locker will lock the diff when one wheel starts to spin freely automatically. However with an ARB, you control when you want to lock the diff. I have a ARB, very happy with it. Good Luck!!!!
Lockers and Towing?
I read somewhere once that you should NOT use a vehicle with lockers to tow a trailer etc.
I have always wondered if that only applied to vehicles with non-selectable or automatic lockers or if it applied to all lockers. If you have ARB lockers or the like then what harm could be done if you towed a trailer say with camping gear in it without the locker engaged?
Maybe it was just bad information...:eek:
is money ever an issue when it comes to the toy ? :D
A good chunk of 14 bolts came with gov locks (which are junk but that is beside the point) You can tow just as easily with a locker.
And when you have an ARB disengaged you have an open diff if it makes you feel better..
tru!!
i vote arb
GO ARB unless you like replacing Birfields, the aussie's can't freespool like the ARB. You only want to use a locker when you need it! The aussie's are allways on and deadly in snow!!!
Learn how to drive in the snow and Aussies are just fine.
And an Aussie can freespool. It just is on when you apply power and one tire slips.
Along with any locker you will want to think about upgraded birfiends. Longfields are pretty much the best..
Two aussies and a set of longfields costs about the same as a single ARB setup..
I do like ARB's for a mostly street truck. But I do nto like ARB's for the potential failure points..
I have a rear ARB and a front EZ locker.
When I installed the ARB the truck was still a DD, so I wanted transparency on the road.
If I was to do it now, I would install two aussies.
The ARB itself has not ever given me trouble, just the many other failure possibilites with the air source.
Kind of not real good with the gear locker stuff, i have a 77 fj40 with stock rear end and i want to put in a locker.
this just came up for sale, question is will it work in my 77 ?
Land Cruiser 1969 - 1997, Rear, 8.875” rg, 30 spline.
THANKS FOR THE ADVICE ,,, :D
Oem
Toyota Electric would be my choice if money were no option. You can even order new from Toyota and have all new R&P front and rear set up by good old Toyota. Poly Performance is making chrome moly axles with the long splines for the locker and then Longfields for the birfs. Of course this would also require you to acquire a full floater for the rear, easy to do. Then you could build your own control unit or acquire the factory units from a salvage vehicle.
I went the route of a front Toyota electric and a Detroit in my full floater rear axle. Thought about the rear electric but decided for my use the ability to control both lockers was not a priority.
I have wheeled my 93FZJ hard with the electrics and have never felt they let me down. The one thing I have noticed in the 40 with the electric locker is it is faster than in my 80. In my opinion it is not the differenciation that is the most important in the lock and unlock it is also related to torque application. The 80 has an auto and will always have some torque applied to the diff, the 40 does not. I have had excellent speed in lock and unlock with the 40 and would not do any other in the front.
I also found a single position pull switch that looks very similar to all the other controls and appears very appropriate on the dash of the 72.
How much is this electric locker? And your saying you would have to go with rear full float with the electric locker? Would that apply with the arb also?
umm, :confused: .
still wondering ?
will this work in my stock diff ? 77fj 40 ? do i have 30 spline ?
and rg 8.875 ?
Oem
You should be able to locate a new locker in the $1000 range from a dealer with a good discount. This is not just the locker. It is a full 3rd member from a 93-97 rear FZJ80 that includes the actuator and is ready to drop in. See the threads in the tech section for answers to the install.
The full floater is needed because the axle design of the stock axle uses C clips to hold the axle in place. The electric locker is not set up this way. In fact in the front you do not even need to inner spring ring in the birfield due to the design.
The ARB is not limited by full floater or not.
I really like the control of the electric front and rear and I can say the Detroit makes it more of a challenge in heavy snow and ice but the 80 series is already the snow and ice vehicle of choice. I like the Detroit for the 40 based on the type of off road use it gets and the compromise of road manners is worth it in my opinion.
