Lex Flex
Tulsa, OK
Website
www.cardomain.com
Been playing around with the front end in a quest for more flex; imagine that.
(1) Spaced down the standard OME shocks 3"
(2) Nixed the sway up front.
(3) Hitch pin mod (welded tabs on to reinforce the rear of the radius arm bracket).
That's about it; and it performed damn good IMO:flipoff2:
That's the hitch pin removal far more than the front swaybar removal - you have a basic 3 link in those pics, that's nice and balanced flex.
Whats a "hitch pin removal" ?
Looks good, probably rides much better on the trail too!
With the stock arms, make sure you have enough clearance, tie rod to arm, when the hitch pin side is drooped. Most will hit the tie rod hard, but it depends on the amount of caster correction.
was seen the Toyteck " extenders " for front shocks .. and looks a option .. anyone using 'em ?
That reinforcing looks good. I was going back and forth about doing the hitch pin mod because I was worried about the stress on the bracket, have you done much wheeling since you've done the mod?
Those pics are not all that accurate. The rear is forcing the front to flex. Put only the front on a big rock and the rears on flat ground and see how much you get.
Just tried it out for the first time when the pics were taken. Truth be known, I've wheeled it pretty hard at Disney Oklahoma with the front bolt pulled before the mod. Nothing broke then, so I'm not concerned at all now.
Does the hitch pin mod really offer that much better off road handling and balance with the rear?
Is it really worth it?
I take it yours doesn't flex this much:frown:
I actually thought the pictures showed exactly the difference. On relatively flat ground, the front is flexing where usually it wouldn't and you'd just have a ton of rear flex.
There is some degree of "twisted" forcing the front to work, but it doesn't tend to balance front to rear in such tame terrain with the stock setup.
Giving all the testing I have been doing with swaybar connected/disconnected this is great flex.
I can't get mine to flex more than 1" with the sway and about 2" without.
I guess my springs are pretty stiff so an FOR spring may flex more.
This is the flex that the hitch-pin mod provides. Those are Slee 6" coils (as stiff a spring as they come), 14" shocks, maxxed out Slee SS brake lines. This is just after I spit out that DS coil. No sway-bar....but I can't get anywhere near that much flex with the pin installed.
