Lex Flex
That looks like Uwharrie right there.
I will have do some investigating in the coming months with the hitch pin.
This is the flex that the hitch-pin mod provides. Those are Slee 6" coils (as stiff a spring as they come), 14" shocks, maxxed out Slee SS brake lines. This is just after I spit out that DS coil. No sway-bar....but I can't get anywhere near that much flex with the pin installed.
That's some nice flex you got there.
Safe to do with Slee caster plates and stock arms? My tie rod is pretty close to arms already.
Wow! Thats some impressive front flex! NICE!
That's the hitch pin removal far more than the front swaybar removal - you have a basic 3 link in those pics, that's nice and balanced flex.
Humm... NO! I know everyone refurs to the hitch pin as poor mans 3 link, but it's not. Count up the links, One, two....
I don't think anyone is actually saying that removing the hitch pin magically grows you another link. However, it appears that the results of removing the hitch pin are similar to the effect of a three link (more/easier flex) without the expense, hence the "poor man's 3-link" comments.
Three.
It's not a true three link, no, but it has a similar effect. And while your third "link" is short (the distance between the front and rear mounting points on one of the the arms), it's still the same basic idea of a 3 link. You're mounting the axle in 3 different locations.
I don't understand which pin is removed. Sorry for being thick.
There are three bolts holding the control arms (radius arms) which one do you remove?
The flex is truly impressive
One of the front ones (either arm, I chose DS so it's slightly easier to get to).
You can see the hitch pin (in place) on my truck. I didn't bother to remove it for that trip.
Ebag,
Thanks for clarifying that you remove it from only ONE side.
being symetrical kind of guy, I would try this mod by removing the pin from BOTH sides.
Hmm, wheels are turning, if I do this mod, can the axle travel up 4" instead of just two on 4" lift.
Ebag,
And the first time you hit the gas the axle would roll backwards under the control arms.
It probably wouldn't fall off....but I wouldn't want to see the results of the damage. :eek:
Ebag,
No. It doesn't allow a huge amount of flex. The total flex is increased (slightly), but mostly it lets the front end flex easier as it eliminates a bind point.
Tried my hitch pin mod this weekend (DS front). Worked excellent. The body stays leveler (new word) while articulating. I was very happy with the results. I have the slee caster plates. The steering tie rod is close to the control arm on the PS, and I had no contact with the hitch pin removed.
i tried the hitch pin mod before i did my three link. yes it flexes "more" than without the pin mod but it still aint no 3 link-it is still flex biased much to the rear. even with the pin mod the truck "unloads" in a violent way. you know the feeling-you drop a front wheel that was stuffed into the wheelwell off the rock that was stuffing the said wheel and the whole truck drops with the falling wheel to the previously stuffed side. it is not controlled. this happens because the front is so stiff relative to the rear. nothing short of a 3 link or a propper radius arm is going to fix it. the pin mod is much more akin to a bad radius arm than it is to a 3 link
so stop pin modding stuff and do the 3 link. you could have had it done by now
https://forum.ih8mud.com/hardcore-cor...j80-build.html
Wow Dusty, I've never seen that thread. One hell of a project you got there. Mine is still the family truxter right now, so its road worthiness is essential.
How did you come up with the time/energy for that project?
True. But it creates 3 mount points on the axle instead of four, which is the functional aspect of a 3-link rather than the link count itself. Pull an arm, pull a bolt...same idea in relieving the bind that occurs between the axle mounts as the axle wants to twist rather than bind among the links so much themselves (the 80 will still have bind within the radius arms due to the narrow arm/mount design).
The functional point is you are allowing the single mount end to rotate without restriction, so any bind is now happening within the arm contact to mount itself, hence the need to reinforce the mount, and the idea that you will ultimately damage stuff if all you do is pull a bolt.
... three. If you count the panhard.
The rear is refered to as a 5link which counts the panhard as number 5
Some so called '3 link conversions' are 4 link if you count the panhard.
there is of course the triangulated 4link which doesn't run a panhard
and an aframe 3 link such as that in the rear of a landrover solid axle. two lower trailing arms and one big aframe which provides lateral control aswell.
True. But it creates 3 mount points on the axle instead of four, which is the functional aspect of a 3-link .... /QUOTE]
yea but still the pulled bolt scenerio still has only 2 links. a 3 link has 3 links. the hitch pin mod is still a radius arm suspension.
so ne ner ne ner ne ner
which of 14" shocks are you using with your slee 6s? are they all on stock mounts or have you modded them? which arms are you running? some nice flex going on there...
also, anyone else running this hitch pin mod with landtank plates? not sure how that would work...the plates arent welded to the oem axle mounts, so would they be rotating freely about the remaining rear mount bolt?
I'd suggest doing similar reinforcement to the front of the axle mount. The front is where I saw the most damage with mine removed.
Ran into this problem on the last outing. Come to find out, the OME bushing sleeve got caught on the bottom edge of the bracket upon "re-entry". It bent the bracket out, and pulled half the sleeve out (2 piece sleeve). I didn't notice it until a little later, but we were remarkably able to hunt down the bushing on the trail.
I plan on flaring out the bottom edges of the bracket so the bushing sleeve can slide smoothly back into place.
