LCEPerformance 1FZ-FE Rebuild kit
The Last Best Place
Anyone use this kit? Any thoughts? I'm exploring different options. Thanks!
A reliable rebuild of the TRD Supercharged 1FZ-FE. This kit comes with hypereutectic pistons which I'm considering.
I read on another forum that their gasket kits and timing sets were Japanese. I emailed to request more details on who manufactures the components of their kit. They say Safety makes the pistons.
It's just a master rebuild kit. LCEPerformance is the name of the company. However, the hypereutectic pistons are intriquing. I haven't seen those elsewhere.
Hypereutectic pistons are a nice addition, but I don't see a real advantage... You can easily get 250k miles out of the stock pistons and the replacements have to be the same mass or it will throw off the balance...
I guess if you are running a turbo or nitrous, you might want something to take more heat, but I don't see the point.
Of course, for the price, this isn't such a bad kit. They even have a kit for my 3FE!
The entire kit looks like it is from Safety Auto part number SEK1578. I would question the quality but without seeing the parts they might be ok. I would rather go OEM for all the gaskets, seals, etc. Then if you really need a high performance piston JE and CP both make pistons for the 1FZ.
Good price-that's the old style HG design. I'd add at least OEM HG. Probably kits that are used on the remans engines listed napa rockauto etc or wherever. T pistons and bearings are $$$.
This motor has 301K on it with a thrown rod. Since it's Supercharged and if I have to bore it, the hypereutectic pistons might be nice. That is, if it turns out it's worth saving.
Are forged pistons the way to go with a forced induction engine? Gapless rings? IDK.
I heard back from them about brands. Here's what they said:
The kit is build by Safety that has made pistons and gaskets since 1970 manufacturing and supplying OEM pistons for Toyota, Lexus, Nissan, Infinity, BMW, Audi Ford, Chrysler, Chevy VW and many others. Bearings are Toyota OEM and timing set is from NTN Made in Japan. The piston rings will be Hastings rings, a leader in piston rings. All of these parts and manufacturers have been building these parts for your application for decades at great quality. Let me know it this helps. Thanks
Found out a little more...
this kit is made by safety in Taiwan, and the water pump in this kit is a Olympia water pump,and that is made in China
Gasket set is safety brand, made by their facility in Taiwan.
I am using the safety branded hypereutectic pistons, hastings rings, and safety branded bearings in my rebuild. I haven't physically seen the pistons yet, I sourced them through my machinist who highly recommended them, it was the only brand that he would recommend aside from forged pistons which are twice the cost and overkill for a N/A build. I am using the timing kit from LCE Performance (I have used their 22R rebuild kits before and had excellent results that met OEM durability over the years) as well as an 'Aisin' water pump that I bought off Amazon prime per recommends I found here on MUD. I am using an OEM gasket kit, with the issues the 1FZ motors have with head gaskets especially, I felt that the OEM source for that was important. I'll have lots of pictures and details in my thread once I get the works back from the machine shop, probably a couple of weeks away still yet.
I used LCE for my 1998 Tacoma 3rz a couple years ago.
What say you MUD on the LCE 1fz kit?
Would you do anything different on your build? Forged pistons?
