LC dash speakers
Cedaredge, CO
Search isn't working very good on my phone right now and I'm heading to camp as I type. I hooked my cb radio up to my dash speakers and finally tested them with a buddy and they sound awful. Are there any speakers I can replace them with that can be purchased at bestbuy or Walmart? I'd love to get these things replaced before we hit the trail.
Oh yeah, it a 97 if that matters....
On the driver side, I think you can replace it fairly easy. PS may require some more work due to the amp being in the way and having less room to fit one in there that's not shallow.
I think a 3" or 3.5" should work on DS.
Usually people install tweeters there because of there isn't much room to play with.
If you have an aftermarket HU, maybe you can hook up the CB to the AUX input of the HU.
That's a good idea about using the aux on the stereo, problem with that is I'm usually jamming out to some bluegrass when wheeling.
I doubt best buy has a direct replacement. I think I'll just grab a 3.5 or 4" and try to attach it with at least one screw for now.
One option I have seen used are some of the smaller external Ham radio speakers. I have a smaller Yaesu and of MFJ external speaker that puts out far better sound than what you find in most of the CB shops with much smaller overall dimensions. Best part you don't loose any quality of sound to your bluegrass without your front speakers.
Just bought a set of kenwood 4 inchers for now, gotta be better than stockers as long as I can squeeze them in there.
Post back up with the results. I'm finally getting around to hooking up my Kenwood HAM, and I want to utilize those two fronts for the two separate tuners the radio has in it.
This might help
I mounted 3.5 inch speakers in the dash...behind the factory grills.. To make room on the passenger side I removed the factory amp and removed the brackets from the amp. Then I velcroed the amp to the engine control unit.
Following what others have done I cut the mounting tabs from the factory speakers.....a screw and a litte JB Weld later....I have 3.5 inch speakers behind factory grills.
p1010921-jpg.536348
p1010924-jpg.536349
I fit pioneer 4” speakers in the dash. As Luke111 mentioned, there is an amp you'll have to relocate (at least for the LX). I removed it entirely as part of my system.
I was under the impression the "dash speakers" we're tweeters not actual speakers
Yes they were tweeters, but there is ample room for the 4" speaker if you want to upgrade. No modifications made other than removing the factory amp. The holes line up perfectly. Made a surprising improvement to the sound quality. I have 6.5 in the front doors and 5.25 in the rear. Upgraded my headliners. Subwoofer has never worked for me. Not sure if the amp is toast. I didn't think I would notice the new speakers, but I'm very happy with them.
interseting... just curious...
are you all running the dash spkers and door spkers concurrently ???
tis my understanding the are factory wired together.
with the stockers this is a no brainer as they are junk pulling minimal current.
but aftermarket full range speakers even arent designed to be ran "parallel" (like a subwoofer)
could burn out the amp on you hu.
tis not the end of the world but was my main reason for leaving the paltry dash speakers in oppsed
to getting a small 4" or a set of tweets that would then require their own amplification and also likely xrossover.
bf
It is getting hard to find any Radio Shack stores anymore, so just stop in at your local truck stop gas station and they will have a variety of small remote CB speakers. Find one that fits for your needs/location. I found one that lays right under the parking brake handle and sounds really good. Cost about $10. John
While my plan all along was to do exactly that and use the dash speaker for CB. But then I added a HAM radio. So decided to use the front firing speaker of the Cobra for CB and then pick a small CB speaker from the local Pilot truck store. I cut the back off it and siliconed the face in the stupid worthless "cup holder" spot. Just drilled a small hole for the wire and ran it back to the HAM radio unit under the seat. Works great.
I thought it would be a "temp" fix, but it has been there for 5years or so and works well.
retrofive,
that speaker looks very nice there. As far as I can tell from the picture, even the color matches.
I also notices you have an AUX IN on your stereo. Many other people have aftermarket head units with auxiliary inputs available. Most HAMs and CBs have an external speaker output which can be used in conjunction with the head unit, so you have all speakers firing and better volume.
Of course it all depends on each person how much music they want to listen to while off roading (I don't).
retrofive,
True, but never wanted to deal with "mono" aspect of it. And I have a upgraded all the speakers and running a 700w amp in the back pushing a JL W7. I like my tunes. And yes, I'm using the aux out of the HAM to the speaker. This way I can run them all independent. The speaker does match pretty close in color. Any that was my solution and I'm happy.
BTW the most excellent speaker wire is sold in many places labeled 12-2 landscape lighting wire.
I can hold up to direct burial, multi-strand and it's cheap!
