Is that frame rust hanging down?
Something hanging from the fork of the forklift, nowhere near the frame as you're seeing the bottom of the tire.
She's a beaut, Clark!Just took delivery of my Nori/Black over Black interior.
I’m curious what the new GX buyer was driving when the 200 was offered new.Just took delivery of my Nori/Black over Black interior.
Having spent a few days in it now, how does it compare to the 200?100 & 200 Series in my case
Fit and finish, any drop in quality with the new platform, interior room?
We have a 460 and a 200 now and the 460 feels much more cramped. Hoping the 250/550 is a step closer to the 200 with front row space.
I was in an Overtrail today without a sunroof — it has lots of front seat headroom. Now I’m only 5’ 9”, but it was way more than my 200 (which has a sunroof).Having spent a few days in it now, how does it compare to the 200?
Dan’s video is up on Car and Driver. RTI 549 connected. 631 with SDM disconnected.
Front wheel spacer does not increase articulation as the up and downs stays the same. It does increase the rear with the solid axle.That's a great result. Something interesting to consider - if you adjust for track width, meaning comparing the articulation angle difference between front and rear axles - the 4Runner with KDSS score adjusted for width is 628 (remember it has a shorter wheelbase so that isn't really quite as much angle). Basically identical to the new LC250. If you put wheel spacers on to match the track width they would be the same on the RTI score. But if you put the exact same suspension on a 112.2" wheel base it and adjusted for width, it then ends up at 614. Close, but a bit short of the LC250.
It's a great result and I think the SDM will be really nice for improving ride quality on the trails by significantly softening up the front end. I'm curious to see how the GX550 does on the same ramp.
That's a good point. I suppose the proper way to describe it is to extend the control arms to match width.Front wheel spacer does not increase articulation as the up and downs stays the same. It does increase the rear with the solid axle.
