Just a heads up on first hand experience.
I run 35" BFG M/T's on 17" wheels (for the last 2.5 years).
My suspensions:
- Front - 2.5", new torsion bars, upper control arms, front diff drop kit, longer travel shocks
- Rear - 2.5", new coils, longer travel shochs
- Also made my own 1.75" body lift for a total lift of 4.25"
I have also re-geared my front and rear diff's and my transfer case for proper trail performance and highway performance.
With this setup I do not use any extra length bump stops nor do I rub on anything full compression, lock to lock.
The only modification I needed to do was hammer down the pinch weld in the rear of the front fenders and remove the plastic wheel well protection. I did not need to do any trimming of any kind.
Do a search on "r2m" and you'll find some pic's of my rig and how it looks.
Things to be aware of:
- 37" tires will put an extreme amount of stress on your drive line components, especially the front diff.
- My set up is more on the extreme side of what you'll find on this forum. You will be hard pressed to find "serious" info for 37" tires.
- Your gas mileage will SUCK, you will be getting gallons to the mile with 37" tires.
- Your performance will SUCK, you will constantly be chasing gears on any grades or hills with 37" tires.
- There are not any gears large enough to re-gear your front and rear diff's to compensate for 37" tires. Your speedo will always be off and you'll still have power issues on hills and grades.
37" tires will work if you are only planning on using your rig as a mall cruiser and soccer transport, but not any serious offroading.
I'm not saying it's impossible to bolt 37" tires on your rig, but the cost to do it right is usually prohibitive for most people on this forum. If someone on this forum was able to do that, they would be on the 200 series forum instead.
