- Thread starter
- #121
Would it be okay to use the top image in the reworked T Shirt design I am working on?
sure.
It’s unreal how dumb this drain is that dumps into the body mount.
Nolen, what are you using for rust converter?Alright. That’s a wrap. I’m very pleased with how this all turned out.
I got the pinholes in the driver fender filled with JB weld. Dumped 1/4 can of rust converter in there. Filled it with Noico and then hosed it with Fluid Film.
Anyone still making cargo mats? If not I’ll make one out of rubber horse mat like I did in Patina. That stuff is legit and kills the sound and heat.
Also, we need two little plastic vents
This was the easy sector I’m afraid. I believe the rust demons are going to be more evident as I move forward but I’m not skeered.....
everyone knows the only pig a black pig. blackityblackblack
The last few hours on the Limo have been deep in the pig guts. This is the stuff that is frustrating because you see just how bad the design of the body mounts, fenders and rockers are ans they just kill these trucks.
The doors all got finished up with the Noico and rust treatment yesterday but the passenger front door was so rusted at the inside bottom that the inner door actually separated from the outer. I think I have a good patch worked out that will keep from having to weld and ruin the paint. It’s curing overnight before I will know for sure. Hope so. I think it’s going to be good.
Next I started in on getting all the mud out of the front fenders, rockers and body mounts. I think the drivers side rocker will end up needing some sheet metal and paint blending like Dave did on Bucky but that will be later. For now it all gets treated and sealed up with a floor BobM panel and some sheet metal I cut and weld in.
I got the floor pan fitted but need to make some patches before it goes in.
Nasty work for sure. I like to dry clean these cavities as often as possible versus water just to try not to introduce more mud to the crevices
Nolen,
Curious how you are fixing the support under the driver floor pan. Was it salvageable?
Floor pans looks factoryDriver side is finished
This was by far the worst side
Passenger should be easier
Taking the day off from it tomorrow for the first time in 9 days to go rescue some pig parts from the scrapyard for the Warthog
Has to go to Tractor Supply for something and grabbed a horse mat to cut for the cargo area floor
Wheres the Ornch?Floor pans looks factory. Love da Sky sunset. This is Sunrise
View attachment 2532172View attachment 2532177View attachment 2532178View attachment 2532187
