Regarding the Rover knuckles using gear oil, all later rovers now have moly grease installed from the Factory. The knuckles do not have drain plugs fitted anymore.
Also, they recommend grease to be fitted to earlier rovers also (definitely the coilers, not sure about series trucks) You can even purchase Genuine Land Rover Grease in a squeezy tube c/w Land Rover logo & a little spout for adding via the fill plug
You also get a pair of warning decals in the pack to add to the slam panel advising grease is installed & not to use EP90.
s-c-r-a-p-e off the grease thats piled on the axle housing and weigh it
Some use a zip-tie as a dip stick, but a sure way is; if there is none weeping out onto the wipers, balls there probably isn't enough inside.
