Hey all. There's a couple threads where these springs are mentioned but I wanted to give some details for people who are interested in them.
First off, I bought mine from "spares box" on eBay for a few dollars less than $200 USD with shipping. They took about 2 weeks to be delivered.
Installation is relatively straight forward. Just follow lift kit directions for replacing coils in a land cruiser. Just be careful because having a loose axle can spell trouble if it's not supported properly.
Anyway, here are my techstream/measurements before and after.
Stock Coils:
Front pressure: 6.9mpa
Rear pressure: 7.1mpa
King coils:
Front pressure: 6.7mpa
Rear pressure: 2.9mpa
The height didn't change and my LX is stock height. As you can see the kings dropped the rear pressure by 4.2mpa. I honestly did not expect it to be that much of a drop.
Now for the ride, it really didn't change the ride to drastically. From other threads mentioning using 80 series springs, I thought they were going to cause my rear to be bouncy due to no change in weight. Not the case. the rear rides nicely, but is definitely more firm. It not harsh though.
The adjustable dampening is nearly gone, but that's because coils are holding almost all the weight in the rear. Once it's loaded up with my bumper and other stuff, I presume it will come back.
I think the spring rate on these is better for our setup.
Btw, the coils measure as follows:
Total coils: 7
Height: 17"
Width of coil: 1/2"
Diameter: 7-3/4"
Diameter - 1width: 7-1/4"
Stock Coils:
King coils:
Total coils: 7
Height: 17"
Width of coil: 1/2"
Diameter: 7-3/4"
