Key won't turn !
Land O Lakes FL - TAMPA FL
Yes its the right key !
No the steering wheel isn't locked !
I had a new key made at Toyota from the VIN # and it won't turn the ignition either.
But while changing the motor mounts we had the motor jacked up to slide the new mount in. During this the truck came out of park some how and rolled down the five feet . We blocked the wheel checked the t case and made sure it was in park.
We are not sure what happened truck was still in 4 high and park.
I can release the shifter with the shift lock release and put the truck in neutral but still can turn the key.
Shift linkage looks and feels great while shifting thru the gears . T case shifts fine.
After playing with the key for an hour I got it to turn and the truck started just fine. It drove and shifted great.
But after the test drive I removed they key and now it won't turn again !
Sent from my XT907 using IH8MUD
Did you guys spray some WD-40 in the lockset to make sure it wasn't sticking?
yes we did. I've searched and read a lot of threads and most seem to be just get the key cut answers. I'veread that the 100s can have a broken steering wheel lock rod cause the symptom. has any one heard of that with an 80? what could've broken when we had the motor jacked up and it came out of park or popped the transfer case into neutral? ( still not sure what happened there or if it's related) or if it's the ignition cylinder that just happened to give up right after the head gasket job just as a spit in the face from this truck.
From this thread:
https://forum.ih8mud.com/80-series-...-cruiser-key-will-not-turn-ignition-help.html
I have this problem once in a while with the spare key Lexus cut. I asked the Lexus peeps about it and they cut another key for me and also said if it happens again try rocking the vehicle back and forth. Of course it happened again and tried the rocking back and forth thing and it worked for me. I have only had this happen 3 times. Hope that works for you.
Thanks Scud, what do you mean by 'rock the truck' Im guessing from outside,
basically I just rock the truck from the front bumper back and forth gently like maybe 5 times.
Worth a shot?
My guess would be you had a key cut to the way the tumblers would be when brand new. Your tumblers are old and worn. So the new key doesn't fit them. I would have a key made off of your old key and see what happens.
As for what happened, I'd say the bushing got dislodged in the park mechanism when you torqued the tranny due to the engine moving:
http://auto.howstuffworks.com/automatic-transmission11.htm
no key fob and no old key wont turn it either. I'm really curious if something broke in the parking mech. it holds fine now but I'd hate to replace the ignition cylinder and still have the same issue. we're running out of time before a trip to the mountains and we already did an unexpected head job in the time we were supposed to be doing the iron man 4 inch and re sealing the transfer case.
evening bump....... has anyone heard of something popping the truck out of park or transfer case into neutral while motor is tweaked changing motor mounts that has anything to do with the ignition.
When I put my tranny back on, my shift linkage was out of adjustment. Don't know why, it just was. I noticed when my truck was rolling away after I put it in park and got out.
Park is basically neutral, but also engages the parking claw, which locks the tranny and ultimately keeps the wheels from turning. I had to push the shift lever really hard forward until I could hear the park claw pop into place. Eventually, I made a little adjustment to the shifter linkage and the problem was solved.
I've had key problems on my old cruiser when pulling a trailer. One time in particular- I parked (with trailer) on a slight incline without using park brake and for the life of me could not get the key to turn. I eventually got it to turn by forcing it while also wiggling the wheel back and forth. But I think the real problem was the incline with the trailer. I had trouble putting it in gear also.
Anyway, to close this long dissertation, next time there is problem with the key, I'd try pushing the shifter forward and see if that helps. I'm not sure if there is a connection between the two or not.
Pat
thanks Pat. my driveway where its parked is on a slight incline but we have exausted every effort rocking the truck moving the steering wheel jiggleing the key to no avail. we messed with the linkage also to make sure it was fully in park. also used the bypass button in front of the shifter to release it, shifted to neutral and still no luck. im no genius but id think if we broke the parking claw it wouldnt sit on the incline without the wheels chocked but it does so i dont think it broke that. im at a loss though. i guess were gonna throw a ignition cylinder at it if no one has any better ideas to check first. i hate guessing by buying parts though, even if its not my truck or my money.
Sorry to add to the already long post, but I just reread it and this is what I think:
You lifted the motor, which put tension on the shift linkage, which disengaged the park claw in the transmission and caused the vehicle to roll.
Then you changed the motor mounts, which, ever so slightly, relocated the engine ( and transmission) and put tension on the transmission shift linkage, not allowing it to go into park well and also causing the tension in the key. I may not happen every time- that how mine was.
So try what I mentioned above, push the shifter forward and see if that helps. If it does, make an adjustment to the shift linkage. It shouldn't be tight, you should be as to wiggle it a little.
Pat
The tumblers in the ignition do wear out. Especially if you have a heavy set of keys. i always fuss at my wife for practically hanging her purse from her keyring while driving. Mine has been replaced, I have two different keys- it sucks.
There is some type of dry graphite lubricant for key holes. Maybe try that.
Pat
