Key won't turn !
So I had this happen to my truck today,I figured I'd post my fix incase anyone else ends up in my position and happens across this thread. It was in the grocery store parking lot so it was a hot ordeal. I did end up getting a ride to get a newer key I had at home, then with the dash apart I tapped on the key cylinder pretty hard while turning the key and was able to get to the acc position to get the cylinder out then started up with pliers. The issue I had was no one here in this small town can get me a replacement for about 4 days so my tinkerer kicked in
I drilled out the small security screw and the 2 press fit nubs that held the front plate onto the housing. With a little prying I was able to get the front off .
I then removed the snap ring from one side put the key back in and while tapping it and turning was able to get the cylinder to come out. You could clearly see 2 of the tumblers were worn and sticking out not allowing it to turn so for now I took those 2 tumblers out and re assembled everything. I told myself when I drilled it out that I'd jb weld the face back on but it was a tight fit so I just left it alone. It's all back together and in the truck working great. It isn't ideal but there are still 4 out of 6 tumblers so it's better than leaving the cylinder out for a week till I can get another one.
I also have 2 keys for my truck, one for doors and one for ignition. Not sure if this is true, but I was told that I could have one side of the key cut for doors and the other for ignition and it would work in both. I have't tried it out yet. Anyone heard of this? If so, it would save us both some money. :)
