Build Keeping another on the road- My Blue 1986 FJ60 Build
Member Build Threads
Installed the OEM muffer this weekend, No issues what so ever it of course is a perfect fit.
Also installed my OEM shoulder belts into my 60.
Because I do not have enough to do on the 60. I pickup a friend for it.
Plan is to strip and repaint and then align the ARE cap to fit correctly and fill any gaps, Seal and then start building the inside. Then a rack for the top for the RTT, and so on and so on. Get the wheels to match the 60 and go from there.
Lots of plans for it, never enough time.
Ok 1st picture coming in later today.
I am crazy. It is zero hour, I have to head out of town tonight returning back late Saturday then turn around and, head out Monday for 2 weeks of fun in the backcountry. Starting in NM I will be following as much of the Continental Divide trail as I can until I hit snow, then I will find a route around, or stop there and head to Salt Lake and visit this LC museum.
All of this in a untested Land Cruiser.
Sunday work (as I have no days left)
Do the valve adjustment, seems I have a louder lifter
Find the transfercase leak and seal some how
After the 2nd alignment fix the steering wheel alignment
Tighten and check all belts
Check the u-bolts and re-tighten as needed
So in my untested 1986 FJ60 Land Cruiser that is a slug uphill with my 32" tires, Carb and H55f (i can keep up to traffic on the flats) I am driving just over 1800 miles to New Mexico to start my journey. Then add an additional 600+ miles and at some point back to Virginia another 1800+ miles.
For the most part I will be avoiding the Interstate and taking side roads wherever I can.
So who thinks I am completely out of my mind.
This is more of an adventure, in a vehicle the may or may not make it. With the exception of the valve adjustment, I think I have done everything I can to make this ready for a trip like this.
With determination and embracing adventure you will make it. Make it does not mean "completing *your* trip", it means heading out your way and doing what it takes to overcome any problems. The adventure is the journey, not getting to your destination. And remember, our L/Cs are simple machines, if you have a problem, find an independent shop that has an excellent mechanic. How? Visit the best local auto parts supplier and ask them, the best local parts supplier will know who the best mechanic is, and they are hidden everywhere, all small towns know of at least one.
Good luck; I have an '86 blue as well, have for almost 30 years and love it.
For the most part I will be avoiding the In, terstate and taking side roads wherever I can.
Where in New Mexico will you start? If you have any issues on the road out in this neck of the woods let us know, a lot of MUD members available to help if needed.
I am going to try to hit this outside of Mimbres. While this is more setup for Motorcycles I am planning on following this as much as possible. I also have some other maps that will help me on the points that are not large vehicle friendly and or on private land.
I will have to make a pit stop in Durango to pick up a Solar Panel I purchased then back track. I have a feeling CO may be out just due to the mass amount of snow still up high but we will see.
The plan was to do NM and CO andif possible part of WY. The snow in 2018/2019 changed some of this. If you have been following this, you would see that anyone in Late June/ July may not make many of the passes and some will not be open till Aug.
You’ll be fine. sounds like fun
You'll be passing by my place really close as you cross the Jemez Mountains from Cuba, NM to Abiquiu, NM:
Let me know when you're getting close, my wife and I could meet up with you for part of the trip in our blue '86 FJ60. If you're interested in a short hike along that part of the drive, there are a couple of old roads down into the northern valles of the Valles Caldera National Preserve Valles Caldera National Preserve (U.S. National Park Service). Your route passes along the northern rim of the caldera, which you can see in the far background of the photo under the heading "The Nation's Newest National Preserve". Back in the mid-'70s a friend and I spent a week backpacking across that area from east to west, before the Forest Service road connected the east and west sides. If you're not up to a longer hike there are a couple of short walks from the road to spots where you can get some nice views into the Preserve.
Cool I will check them out and send you a shout out.
So 2000 miles in only a few days what I have I learned about my Land Cruiser.
First, and this is for every new owner, Get all mechanical sorted out.
I spent a crazy amount to time rebuilding or replacing just about everything on the drivetrain. Cooling system (everything), AC, Steering, Alt, u-joints, suspension, exhaust, axle rebuilds etc.
I had 4 issues
1. Needed to tighten the drive belts (they were new and needed it anyway)
2. Get mechanical gauges. When the wire fell of the oil pressure sender (no idea how) I was doing 65mph and was like WTH. Looked at the mechanical gauge and 80psi (where it had been all trip) so all was good. Fixed the wire at the next stop
3. Steering. while OK with the med/ heavy suspension and the steering not 100% dialed in it seemed It had a tendency to wonder a bit.
I believe this can be corrected easy enough with a bit more toe in and less crap in the back. It was sagging a bit more than I would like. Even though I have heavy springs, my shocks are med for a better ride. How to fix, I have a set of airbags to install still. Or change the shocks, but then the ride would be unbearable. Even so, it was nothing that made me go, oh crap.
4. My heavily pitted windshield has to be replaced. At night it is OK except when a HID or LED headlight hits me square on (blind curves suck). It was the sun in the late evening that was scary.
Favorite mods
1. H55f. Even with 32" tires and stock 3.70 gears this was a lifesaver on the interstate. While some hills I was stuck in the slow lane, for the most part I was able to pass when needed.
2. LED bulbs in dome light. I bought the kit from a vendor here in mud. I forgot I had installed them and needed light at night. These make the cab seem like you are in daylight. Awesome
3. (unexpected bonus) Due to not having time to paint the 60, the hood is still hot rod black. Sun hitting it in the right angle the black hood soaked up the glare and saved me several times.
4. HEADLIGHTS I installed the Koito headlights and seeing these on the forums are fine In person at night on a dark road. Low beam is great, high beam is fantastic!
5. Rebuilt OEM seats (foam and covers). Longest time was 15 hours (total time) in the saddle, really about 6-7 hours with fuel stop and coffee, never once was I uncomfortable. Also at 6'1 with a 34" leg the OEM seat was perfect for me.
My 60 is still carbed. I know the secondary's are opening and have not looked that the throttle rod yet. to see why the secondary's only open when almost at the floor in any gear (yes you can actually feel it)
I was planning on going FI, however I am still not convinced that a system not designed for the 60 is in anyway worth the cost.
After 2000 miles with a carbed engine, I am still not sure it is. Planning traffic merges, lane changes and prepping for hills the carb worked fine at 65-70 MPH (kept it a 65 for 99%). I was able to pass the big rigs and oddly some other vehicles when needed.
Most of the time in 5th with the gas pedal pegged on the floor. Better gearing would help and needed anyway.
One thing I knew is that my engine would always start. Even after driving for 6 or 7 hours and then needing to stop, it would start hard (like there was not fuel in the bowl) but it still started. I chocked it up to heat in the engine bay.
It stayed around 165-180 along the whole drive and crap up to 185 when stopped. I though this was perfect.
Heat soaked it was about 200. If I let it sit for 1/2 hour it fired up every time.
Never once did I have to worry if my new EFI system was going to crap out on me, my old system always worked no questions.
So so far everything is running very well. Lets hope it stays this way.
Yes it is currently registered in VT, I need to move it to VA.
That's a great looking 60.. I wouldn't paint it, it looks like it has some great character.
So did you complete your long trip? Howd it go?
Well took a way different route than planned. discovered my right rear brake was dragging so fixed that in a rest stop. After all of it I decided to get a new power plant.
Already planning next years and going to try to incorporate SAS in there as well as all the way to Nanaimo BC. So the engine needs to be installed and ready
Took the harness off (need to send the computer in for reprogramming) the engine and pulled the plugs.
Looks like there was at least one O2 sensor that was bad as I can see it was running a little rich.
However all plugs looked good overall with no sign of wetness.
Next is to pull the accessories off and Clean up the mounts, etc.
Only doing a cleanup or the valley and sourcing a LS1 intake. A Holley 22-101 water pump and the intake will be good to go.
Nice as it will be a lower intake with minimal to no modifications. I was planing on replacing the water pump anyways.
I am not pulling the heads so this is as far as it will get.
All accessory mounts will be cleaned up as well.
I'd change your plans on the intake and either stick with the truck intake or source a Gen IV truck intake (AKA TBSS intake) which is good for about a 20ft-lb torque gain at the bottom half of torque curve. You can buy the Gen IV truck intakes new on RockAuto for like $100 but you'll also need different rails, etc. Also an aftermarket 4-bolt throttle body to keep it cable-drive. Sometimes you can get complete intake/rails/injector setups for good deals on Ebay or pull-yards. LS1 intake will be a downgrade on any engine. You'll also have to change your belt setup for it which isn't a big deal but just something you should know. This is also where I should mention it's usually best to avoid changing a bunch of things to keep your swap more simple.
You should buy the muscle-car/H3 pan kit. It's $200 from Summit, Amazon, Ebay, etc for a new pan, windage tray, dipstick, etc. Great deal that gets you better clearance around front driveshaft.
That motor looks nice and crusty, and unmolested. Which is a good thing.
