- Thread starter
- #101
Nah, this is great advice! The engine is actually a 2F from the following year (1975). I like the screwdriver-on-a-drill move, thanks!
That makes zero sense. I welcome your thoughts!
Would just jumper a hot wire from the battery and try to make it run, if you can make it run with temporary fuel and power then at least you know you have something that will work once you track down all the rest of your unknown issues.
...Is there a fuse for the ignition? Perhaps that's a nOOb question, but I'm hoping there is so I don't have to track down a melted wire.
IMake sure you put the rotor back in.
Rough time the motor with it at TDC.
Check for 12v at coil.
Check points gap.
Check for spark after that at coil wire.
Sorry, jumped the gun and missed the troubleshooting.
Ign fuse or ignition switch would be the guess
I
DoubleNickels, How did the engine fuse look? Do you have juice there at the fuse panel?
What distributor are you running? Some DUI have two cap notches. It can prevent it running due to spark offset. It's possible to have the wires offset if it's the stock dist.
Hey, look at that. There's a fuse there. Odd that this schematic doesn't show it as connecting to anything, however. Still, good place to start!
When you set the distributor in did you confirm the engine was TDC on the compression stroke for number one cylinder and the rotor was pointing to number one on the distributor?I think you're saying it's possible to have it ~120-degrees off since the screw holes line up, yeah? I'll quadruple check.
I was thinking early on, maybe 180 degrees out, I've done it before. If I remember right though, it would pop and try to fire.
