- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
- Thread starter
- #141
Stuck a bunch of parts on the motor, including the trans & transfer, stabbed it as a unit. Notes:
Cant use the load leveler, hits the firewall.
Remove the driver's side bell housing motor mount bracket and if it has '60 steering, remove the lower column shaft, makes life much easier.
Make sure the cherry picker is fully extended, otherwise the jack runs into the front cross member before the motor is in place.
Once in, the intake was solid into the brake booster and the lifting hook interfered with the heater valve. Will take pix, but moved and tipped the motor to passenger to get clearance.
