- Thread starter
- #61
Initial Sandblasting Results
Yesterday I did my first session of sandblasting. I focused on the rear frame rails as this is the heaviest rust on the truck so figured if I could make it work on those sections would work on any are of the truck.
Below are some pictures of the results from my first session of blasting. I blasted for about 1.5hrs. My compressor is small (2hp) so I have to blast in short bursts, approximately 10 secs and then need to let the compressor catchup. Isn't that bad becuase need to change position frequently.
It took me a bit of trialing to get the right setting on the media valve so that you get right amount of media in the air stream. Too much media and it just "pukes" out onto the work piece rather than blasting. Too little media and you waste valuable air without efficient cutting. As well, I learned that I need to shut the media valve when pausing to let the compressor catchup. After about 5 to 10 secs of the media valve being open without blasting, it will fill the hose with sand which you need to purge prior to blasting. This is more annoying than anything else because the media can be easily recovered when the hose gets filled.
If any of you guys have experience with small pot blasters and advice, please feel free to PM me or add your opinion on here. Is always good to hear what others have found.
