Rear Suspension Finally Out!
Today I dropped the rear suspension. The air compressor with the impact wrench did quick work of the rusted FR and RR shackle bolts. I was surprised at how easily they came out. I had been soaking them for about a week in WD40 but not sure how much that actually did.
The nuts came off the both rear and front shackles, however, the getting the pins out of the hangers was another story. The FR ones were pretty good, took a couple of good wacks with a hammer, then was able to pry them out from the outside with the puller on the hammer. The rear shackle pins wouldn't budge. I wacked on them with a hammer, then a 5 lb sledge, didn't get any movement. I heated them up with a torch, still nothing so I ground the head off the pin (outside) thinking that the flange surface was ceased to the shackle, however, still didn't work. Tried heat again but still couldn't get it to budge. I was starting to bend the shackles so figured it was useless, then cut through the 2 sides of the shackle with a cutting disk on my angle grinder.
Not pretty but it worked and the shackles need to be replaced anyway, so do the hangers. I was hoping to reuse the leaf springs as they didn't seem to be in too bad of shape, however, as some of the pictures below show, the FR collar was cracked on both LH and RH sides so now I will need to source new rear leaf springs.
Below are some pics of the Rear Suspension coming out.
