J Arms
i have been looking at lift kits. And was wondering is anyone has made there own j arms using Polly bushings and Dom tube like if you build a 3 link and just bend to factor curve and longer.
Are you referring to the front axle control arms?building your own control arms will require a bit of math/engineering to get the castor correct to compensate for any suspension modifications. I personally have not seen or heard of this. I have, however, seen where the stock arms were flipped to the top of the axle housing for additional ground clearance.
Slee makes a set of replacement arms for a 6"+ lift. Check out Slee Off Road.
Yeah I have looked at there arms and I'm not wiling to pay the price when I can build them for half the cost
Why the need for custom arms? Are you planning a lot of lift?
No I don't want a lot of lift but I do want to run 37's. I want to do 2"-3" lift coils posably with coil spacers. After reading on here doing the arms is a good idea. For the tire size. I haven't got to much information on if most keep the stock arms and just do coils or go with slee's setup. At this point I'm all ears and open to anyone advise on lift and for the best bang for the buck. And I have already started trimming fenders for the 37's. My first 80 build most of my other project where Toyota mini truck and Suzuki samurai with all Toyota drive train and running gear.
There are bushing caster correction kits and caster plates. Otherwise the Slee arms or go 3-link. There are also Trunnion Caster Bearings available. Do a Search for each and you'll see many threads.
If you want to see a similar progression thread, look at @jcardona1.
Lots of people (I would say the vast majority) running 37's still have stock arms with caster correction plates or bushings. Unless you have a particular need, I would forget the idea and save your money.
I say go for it, if you really want. But a bent piece of tubing isn't going to be all that strong. But you could do 2 tubes and plate it up and gusset it. If you want to do it go for it. Just make sure you have your numbers right to rotate the axle where it needs to be for a lift that you don't have yet.
The Slee kits were put together after a lot of years of trial and error, they don't really have a lot of extraneous things in them. If they are in the kit, they are needed, for the most part. You could get by with a Slee 4" lift and run your 37's quite easily. Or if you want to trim the fenders out like you said, you could do a 2.5-3" lift, run the bushings and call it a day.
