Build “It’s only an axle swap and a motor swap” aka AK2AL aka Dream Build
1:37pm
3.5 hours including lunch. AC disconnect was the hardest part.
Not looking forward to that..
with my quick measurements, raising the body mounts 1”ish will clear. I’m not going to move the coil buckets for 1”. I’ll need 2-3” of lift with 35”s and with frame sliders and new bumpers, you won’t ever notice it visually.
I’ll measure and cut more next week and report back :pig: :pig: :pig:
What? Next week??? Looks like you could have it done tomorrow!
Have to go to our if town Monday.
-weld on radius arm mounts
-order body mount rubber
-trim body
-make frame body mounts
-cut frame some more, see if 55 tank will just bolt it
-80 body to scrap yard
Then
-get 100 in shop and motor pulled
-motor tune up
-assemble motor, bellhousing, tranny, tcases
-set into truck
-make motor mounts and Tcase mount
then.....
-Thursday
Measure, cut, measure, cut, measure, measure, grind, ratchet strap, cut, strap, weld
cut 5.5” out of 80 frame to get wheel base to match 55+ 1/2”. Moves front axle forward a little.
Nice work man, you are getting busy.
Keep the pictures coming!!!
