ClemsonCruiser said:
So if this has happened, it is time to pick up a new 3spd. tranny?
Thanks
JP
No, just put it back together properly. As long as you didn't pull the tranny output shaft part way out of the transmission, you should be OK. If the rear tranny bearing is sticking out of the case , you may have a problem.
Now that you have the transfer case off, this is a good time to verify that it is actually shifting. It is possible to install the top cover without having the pawl of the shift arm engaging the slot in the shift fork. You don't have to disassemble it to check this. Jus turn the idler gear by hand while holding the rear output flange and then shift through Hi, N, and lo. You should be able to feel when the idler gear disengages from the putput in N. If you can turn the idler gear without turning the output flange, then it is in N.
If the tranny is shifting fine, then the problem is either the clutch or the tranny. ou can also check this without disassembing anything. Put the tranny in gear and then try turning the tranny output shaft. If you can't turn the tranny output shaft (without steping on the clutch), then it is working normally.
If the tranny and transfer case are both shifting normally, this leads to the clutch. The disk may have been installed backwards, so it doesn't make enough clamping force to move the truck. If you had the flywheel macchined, it is also possible that this was done improperly so that the pressure plate cannot develop clamping pressure.
