Inverter Mount Question
"the whale's vagina", CA
Hi There,
I am working on doing a dual batt system in my 96 80 and had a specific question on cable size when mounting an inverter. I have a xantrax 1000W inverter. The manual says that I should not mount it in the engine compartment, and that the DC cable (the one that goes to the batt from inverter) should not be more than 5 feet long. Well, that really limits my options. The only place that works with these above rules is somewhere in the pass seat area below the dash. I could not find a place I liked.
And thus my quesiton. I would like to mount the inverter in the back, in the cargo area, right inside the little storage area on the pass side. To me this would be the cleanest area and way to do it. I can then run standard extension cords up to the pass side tranny tunnel and mount a plug receptacle there as well as one in the rear cargo hull plastic side sheeting. I also plan to run some round type automotive accessory receptacles in the front and rear, but those will be powered direct to the batt and wired completely seperate with the appropriate fusing.
So, according to my measurements, the DC + cable going to the batt would be about 11 feet long. I am thinking if I use a larger guage cable than what came with the inverter I will be ok? I just wanted to get opinions on whether or not I need to really stick with the 5 foot rule the manual is giving me? I would really like to mount the inverter in the back. I don't see it getting a huge amount of use, mainly lap tops, coffee makers, hairdryers, etc, but I would like to make it all look clean. Have others mounted their inverters here and have they had a problem with the length of the DC cables going to the engine compartment?
Thanks,
Noah
I'm installing a 1500 watt inverter behind the back panel. I'm using 2/0 welding cable from the battery, to a BlueSea fusebox and then on to the inverter. A 300 amp Megafuse keeps things safe.
I mounted a 850w inverter under the drivers seat, also ran a wire for an auxillary 12v distribution block. I'd have to look at my notes, but I just used the appropriate gauge wire for the length and load. You may be limited to 5 feet based on the wiring they provide, but you can put it anywhere as long as you use the right gauge wire. Make sure you fuse it, at/near the battery, with a lower amperage than the wires capacity. You should be good to go!
EDIT: Oh yeah, I ran the wire through the firewall and under the carpet along the door thresh hold, IIRC. Removed the drivers seat (easy), and used sheet metal screw to fasten the inverter to the floor. It is not easily visible, and far enough under the seat that it won't be kicked by a rear passenger, but you can plug things in right under the back of the driver seat
I have a 1000W inverter in the rear , I went thought the frame rail/box and across the back for a 25' run.
I think its # 2 wire but I also have a aux buss off it.
ken
what size fuse did you use? the instructions call for a 150adc fuse, the inverter says on it 12vdc, 120A max., so am I correct that if the max input to the inverter is 120A and I have a fuse for 150A this should cover me as far as any weird or dangerous spikes?
so it sounds like I should be ok with this length? I really want to mount it there as it would be clean and out of the way. I then plan to run the AC lines back up to the center console and another AC line to the rear where I will put in receptacles. any problems? Do I need to do any fusing or circuuit breakers on the AC side of things? I would think NO as any problems would pop that fuse on the DC side of things, here is the one from blue sea I plan on using:
http://bluesea.com/category/5/22/productline/overview/134
This sounds good to me, as long as the wire gauge/length can handle 150A
well I was planning on using 11 feet of 2 guage welding wire, again along with a 150a fuse, any comments?? the inverter came with 4g wire, but I figure since I am lengthening it quite a bit, I should use a heavier guage wire to compensate for the distance.
another question, why does the neg battery cable have to go back to the neg battery terminal post?? I have read and heard that it must go back to the neg battery post when using an inverter? why is this? I called xantrex and they told me it is because it needs a good ground. Couldn't the same thing be accomplished by grounding that cable to where the neg side of the battery ground to, ie: the frame? Especially since I am using dual batt's and both batteries will be connected via a blue sea simple switch, it shouldn't make a difference where I ground the wire, should it? I would think I could even maybe find a good ground in the rear of the car, possibly somewhere on the frame, not sure where I would find an exit point in the rear of the car though, but I am sure there is one.
I googled "wire gauge capacity" or something like that. I found several charts, nothing concrete, but made a choice on wire gauge based on some of the capacity info I was able to find.
I think they are covering their rear. AFAIK, if the ground is good, there is no difference whether it is through a wire or through the body/frame.
found this:
Recommended Power and Ground Cable Sizes
which shows that to support 1000W, I need to use 2 guage cable
and this: American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies
which tells me that at 120A, which is the MAX power of the unit, there is about a 3.5% drop in a 11 foot wire, or .424 voltage drop. Which tells me that I should be fine as long as I don't expect the inverter unit to run at peak efficiency. I am willing to give up a bit for the unit to be setup cleanly where I want it. Interesting web pages.
even more interesting when you put in 2 feet length you get 11.923 voltage at load end of circuit, and if you put in 11 feet, you get 11.576, so really in the end not much of a difference at all.
In fact if you change the wire guage in the calculator to 4g and choose 2 feet length you get 11.87 at load end, 4g is what came with the inverter.
SEA Fuses - Blue Sea Systems
I don't know whether your model has an internal fuse but some Xantrex 1000 watt models use an internal 150A fuse which means that if you use an external 150A fuse and the inverter causes one to blow, you stand a 50/50 chance of having to dismantle the inverter to replace the internal fuse. Something to think about.
This is what I use for inverters and would consider to be the industry standard. Unfortunately, I'm not enough of a fuse expert to explain the differences:rolleyes:
Class-T Fuses - Blue Sea Systems
It depends on how you really plan to use the inverter. If you will rarely if ever push it to its limit, that should be fine. If you plan on pushing it to its limits regularly, I would use bigger wire.
The negative battery post provides the cleanest, most high current connection point. That said, you should be fine to connect the same gauge ground cable from the battery to the frame and from the inverter to the frame. You would never want to ground an inverter of this size to the body.
and this:
Bear in mind that it will take more tham 1000W DC to create 1000W of AC. It is also common practice to oversize wiring and cables to be able to pass 120% of the necessary current.
the inverter I have has a "fault" light on it, most of the newer electronics use resettable poly fuses that reset themselves shortly after tripping. I am guessing it probably uses one of these. The issue with these fuses is that they are not as completely safe as the old standard wire type fuse and with big spikes of amps (short circuit) the power can possibly cause trouble down the line and into the device, thus the reccomendation in the manual to use a blade fuse. I used to sell chip fuses. I should probably know this stuff better than I do.
I plan to call xantrax and see what rating fuse I should use for my particular setup. I hope all goes well with the length of cable I am using. I am guessing after reading the manual again that they stick to the 5 foot rule so they are not sued for possible fires when some asshat runs his inverter in the back of his motorhome without fuses with 18 guage wire.
any other help or opinions appreciated, especially from those that have mounted their inverters far away from their batteries.
Noah
also wanted to ask again about the AC lines coming out of the inverter, is there any problem with their length. My understanding is that AC power is much more tolerable of length of transmission with less loss than DC power, correct? I was planning on running extension cords from the inverter back up to the center console and a short extension from the inverter to a spot in the rear cargo area as well.
Sounds fine , sounds like pretty much what I did. I used to extension cords (12ga) for there nice molded plugs to go into the inverter and I ran them to 2 marine 120vac receptacles.
Works fine , I have no fusing on the ac lines.
I think your going down the right road , dont over think this..
ken
cool, thanks 450 dude, I do tend to overthink things a bit, but my fam is riding in this truck and I want to make sure things will be safe, good to know that you basically did the same thing as me and it has worked out well for you, great, appreciate the feedback.
and yet another question, anyone know where to get some nice looking 120vac outlets? function wise they would be the same as in your house but I would like to find something a bit nicer with covers on it. I looked online at the marine stores but no luck.....
heres the way I did it, in case you missed my post awhile back. I mounted the inverter part of it behind the panel, after seperating the outer case of it that includes the touchpad. Cut a hole in the panel, flushed the cover in with Gorilla Glue, then put in the 120V receptacles that were part of the original inverter and added a duplex 12V also. Just and idea for ya.
My 1kw Magnum is mounted in the rear quarter with a fuse in the engine bay near teh battery. You can run 11 feet you just need to use the correct cable size. I believe we needed 2/0 for the run. It has to be capable of handling the peak / surge ratings your inverter is capable of. Do not skimp...you must use the proper cable to get the rated performance and for safe operation. Make sure you use a fuse as well .... do not skip this step.
