For Sale Intercooler Kit - 3B, 13BT, H, 2H, 12HT for 40, 45, 55, 60, 70 Series
60 Series, all buttoned up! Radiators can be passenger side inlet and outlet depending on your engine setup. I routed this coolant return over the top.....plans for more accessories on the other side!
Hi TurboScott,
I have a 1988 BJ74 RHD with a/c , is your kit going to work with the A/C ? What was the price?
Thanks
Hi TurboScott,
Thanks
Sure. We can fit it, then you just alter the routing to not be "Direct". The kit is $1250 which includes the radiator, intercooler, silicone fittings, clamps, charge pipes and brackets. If you need extra pipe or fittings for the indirect routing, it will add a little, but not much.
If you want to move forward, I just need some pictures and measurements!
I’m not sure what you mean by “not direct”.
What pics and measurements do you need?
Will I need to remove or trim the fan shroud?
I’ve been experiencing high EGT’s since the rebuild and think this will help.
Just give me a call and I can explain, answer questions and explain the measurements needed! 239-465-1866
Did you end up using the factory shroud on the 2h
You can't use a factory shround on an intercooler swap. You are removing the stock radiator and shroud. Installing an aluminum racing radiator and intercooler stack in its place. Some people choose to adapt their factory shround to the stack. Others just leave it out altogther.
kinda need a shroud.....
air through the rad is significantly reduced otherwise
With the stack, there is only a 1/4 inch gap between the new radiator and the intercooler, so it acts like the sides of the shroud on a full length shroud.
Because the new radiator is probably 40% more efficient that the old one, every installation we have done so far....the car has run cooler WITH the turbo and intercooler stack that it ran without the turbo and the stock radiator.
Technology has changed......quite a bit since these cars where made in the 70s and 80s and the radiators don't need the same constriction as the old one did to perform well because......our advances in both design and manufacturing process have made them far superior!
i just mean the shroud behind the rad is ducting air through the rad and capturing the blade 'wash' off the fan tips and making sure all the fan effort is put into going through the rad instead of slapping the air around the engine bay...un-efficiently.
Im not necessarily disputing the increased cooling of the newer rads
But if the new rad doesn't care about the "slapping" because it doesn't need that efficiency anymore.......why does it matter?
i guess.... to each their own
but i think that answer is beyond the data points i have
other than, shroud = good
My argument would be.....efficient cooling = good. shroud used to be necessary for that, with new technology....isn't. advances are good! Numerous folks have modified their shrouds to work when they install this intercooler stack. So its possible, just not necessary! Have a great one!
