I have a question about installing the power steering pump gear. From what i see in CDans post it should be torqued to 54ft/lb. But as it is a gear it will rotate. To remove it you can hold it with a glove and hit with a impact. But how are people torquing to 54 ft/lb? Obviously you could lock it in a vise with wooden blocks. But i just dont see much talk of this. Also it looks like the depth is critical. So i assume you tighten it down until it is at the right height. but is that always at 54 ft/lb? How are you guys torquing the gear?
