do you mean "not in the cluster" or "outside the vehicle"?74fj40 said:just wondering if it is possible to install an external tachometer???
nuclearlemon said:do you mean "not in the cluster" or "outside the vehicle"?
TonkaC said:as long as you have a coil, run the wire to the trigger side of it. That should let you run it. Most have a switch to change from 4/6/8 cylinders. Once that is done, it should count each time the coil fires. The trigger side is the one that doesn't have 12 volts all the time.
PabloCruise said:That is what I was wondering too.
But I'll jump in w/ a question here; I plan on buying a little tach to mount on steering column. How do I hook it up to run off a stock '78 dizzy?
