Immediate help needed!!!!
Longmont, CO
I have a question that I need help with as quickly as possible guys. It is time sensitive. Thanks,
I went to go buy a 76 FJ55 from a guy here in town. When I test drove it earlier this month it was driving fine for about 25 to 30 min when all the sudden it died and would start. Since it was a hot day I assumed that it was vapor lock or the fuel filter was clogged. The cruiser had been sitting for about 2 to 3 years. So I had a strong feeling that it was a clogged fuel filter. We towed it back to the guys house and I went home.
He called me a week or so later and said that he had put a new fuel filter in and that it ran fine. I went down this afternoon to check it out and possibly buy it and when I got in it and backed out of the driveway it died on me. It would run with the choke pulled all the way out but the second you push the choke in or feather the gas it would die. Well I naturally got very worried. I pulled the new fuel filter and tried to blow through it and did very easly but when I did red fuel came flying out of it. :crap:
So we pull the line from the carb and I see all kinds of rust right where the fuel line hooks up to the carb.
My question is....
How detramental is this to the carb and or engine?
(it has the original asian carb on it)
What is the best course of action? Rebuild the carb, if so by whom, because I know they are tricky to say the least?
Is there a chance that I may need to also rebuild the engine?
I need responses as quck as possible please.
Thanks guys.
The carb probably has a screen in it. The tank would need to be removed, cleaned and lined. Probably a rebuild on the carb. Does not sound like a deal breaker to me
:beer:
Ed
Sounds like the carb may need some cleaning. You can substitute a gas can as the gas tank to make sure it has good fuel. Make sure the points are not grounding out or need replacement and causing it to turn off. I would do a compression check to see where you stand. Checking for overheating and oil pressure problems would be my biggest priorties if I were buying it. Let him know you are interested but want to make sure runs before you commit or let him come down on the price.:). Good Luck.:)
Maybe you can use it to your advantage and get a much better deal!!! Put a seed of doubt in the sellers mind.
Not much help to answering your question tho.
Brian
Red fuel is normal for old gas. It turns into a varnish that is really nasty and usually clogs the pickup. The old gas is flamable but not really. Take a fuel can over there and some rubber fuel line. I bet it will run fine if you pull clean fuel from the can.
