I have a feeling that I'm not the only one with this problem. My driver's side power seat has had this problem where at any point in its fore/aft travel except all the way forward or all the way back, it would move a 1/4" at sharp stops or take offs. It was never a huge priority for me as I always have the seat all the way back, and had attributed the problem to a likely worn gear. Well, last week the cap popped on my seat and the gear stripped. Ordered a new gear and did the repair, including replacing the big rubber washer next to the gears with new ones (which just made the motor struggle) but the slop/movement is still there. When I had the seat upside down, I could see that the slop was coming from these 2 brackets where the red arrows are pointing (this is not my picture). It would seem that whatever is inside these things that the threaded rod spins inside of has worn down, causing the slop.
From what I can tell, these things are not serviceable? Do you guys think my diagnosis is correct? Anyone else have this problem and fix it? Please help. Now that I'm letting this issue bug me, it's very annoying!
